8 members (Robert Crandall, carbking, Gdads51, MikeStone1953, walter74, Bill Hanlon, Steelonsteel, 1 invisible),
141
Mod | | | Forums66 Topics128,204 Posts1,057,310 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 10 New Guy | | New Guy Joined: Oct 2009 Posts: 10 | I just bought a frame and now I'm looking to add running gear. I'm just curious what rear end you're using in your AD and what trials and tribulations you went through to fit it up.
In case anyone is interested I have a 1953 3100 5-Window. My vision is to keep a stock look to the truck, but to modernize the running gear to make it more enjoyable (IMO) to drive.
Thanks for participating.
1953 Chevy 3100 5-Window
| | | | | Joined: Aug 2004 Posts: 1,418 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,418 | Go with a set of Patrick's 3:55's. You cant go wrong.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Mar 2008 Posts: 3,750 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 3,750 | There's plenty of options available to you,it just depends how far you want to go and how deep your pockets are. Plenty of folks here stick with what's there but just change the rear end ratio as SWEET mentions. That'll give you reasonable highway cruising ability,without breaking the bank. Try a search and you'll open up a regularly discussed topic. 1950 Chevy Advance Design 3100 in ScotlandIn the Stovebolt GalleryMore pix on Flickr. I've definately got this truck thing in my blood ... my DNA sequence has torque settings"Of all the small nations of this earth,perhaps only the ancient Greeks surpass the Scots in their contribution to mankind" Winston Churchill.
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Your '53 is not a "first series" anything. First series refers to '55 trucks that look like '54s. Some people also refer to '47 trucks that look like '46s as first series. | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Kzoo, I am running an 84 GMC 1/2 ton rear end with 2:73 gears and a 283/TH350. It is not a ball of fire away from a light but it cruises very nicely @ 55/60 and will give 16/17 MPG. BTW it is a 49 Chevy suburban.
Weeds | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | I have a 54/3100 with a 235 with fenton headers and offenhauser intake. the rear end is a 79 nova with 2.73 gears and an s-10 5 speed trans. it does fine in fifth gear from 45mph on up on flat land. long uphills sometimes require 4th gear especially when i have the cruise control on.
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Oct 2009 Posts: 10 New Guy | | New Guy Joined: Oct 2009 Posts: 10 | Cletis, Good catch ... keep the AD ditch the first series.
| | | | | Joined: Nov 2009 Posts: 33 New Guy | | New Guy Joined: Nov 2009 Posts: 33 | I have a 50/3100 and am running a 1969 10 bolt from a camero with a 350/th400 with 2:73 gears. | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 | Mid 70's Camaro with 3:08 gears.
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | | | | Joined: Jan 2003 Posts: 68 New Guy | | New Guy Joined: Jan 2003 Posts: 68 | I'm running a 14 bolt full floater from a 70's 1 ton pickup. They're plentiful and fairly easy to find in the parts yards. They are considered "bulletproof" by the 4x4 folks, even though mine isn't 4x4. Mine is attached to a 350/350 combo. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Well, I pulled the torque tube out and installed the pumpkin out of a 56 pickup. So, I went from a 4.11 to a 3.90. Not much of a gain but hey, it was free and got rid of the torque tube!. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | I did the same thing Achipmink did. Add on a T5 and you'll have a good freeway cruser. George | | | | | Joined: Sep 2009 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 48 | 89 posi 10 bolt from a camaro fit just fine, using the saddles and custom ubolts from buffalo enterprises worked awsome, and I also used the lokar E brake cables for 47-53 chevy pickups, it worked out great in my 1953 3100 | | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | Your '53 is not a "first series" anything. First series refers to '55 trucks that look like '54s. Some people also refer to '47 trucks that look like '46s as first series. Just out of curiosity...is a 52 a 1st series? I only ask this, because some of the truck part vendors call 47 through 54 1st series while the 55 through 59 is a classified as a 2nd series...any clarification...? | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | the vendors are trying to prevent you ordering parts for the wrong series, usually applying to the year '55 only as the 2 versions of 55 are common - some might call any TF year [55-59] a "2nd series" .... the terms apply only to 47 and 55, no other years
the "first series" is the model that looks the same as the previous model series, the 2nd series in any case is the model that looks like the following series .... Deco "series" = 41 to 47 1st ... AD "series" =47 2nd to 55 1st ... TF "series" =55 2nd to 59
Bill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | run that one by me again to make sure I heard it
are you saying 47-55 Are T F
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | no Fred, the term "1st series" applies to either a 47 Deco or a 55 AD, the term "2nd series" designates either a 47 AD or a 55 TF, but then you knew that .... some of the suppliers call all the TF years "2nd series" because they don't pay any attention to the 47 1st and 2nd folks that don't understand the 1st/2nd situation [not you Fred] should read up on GM post war production and labor problems in the auto industry  Bill | | | | | Joined: Sep 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2009 Posts: 46 | Narowed 9" ford with 3.89 gears With a locker in it with a 4 Link Suspension. | | | | | Joined: Nov 2010 Posts: 52 New Guy | | New Guy Joined: Nov 2010 Posts: 52 | thanks for the clarification...:>)
| | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | 12 bolt out of a 74 C10 on chassis engineering leafs.......dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Nov 2005 Posts: 238 Shop Shark | | Shop Shark Joined: Nov 2005 Posts: 238 | In my '50 truck I have a Dana 44 rear end from an early sixties GMC or some Chevy 1/2 ton pickup, it has 3.54 gears. I have installed A Detroit TrueTrack Torque biasing Diff. Truck has a 350 motor and Tremec TKO 5 speed manual trans.
Stuart. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | alright I am going to sound like an idiot regardless but can someone explain to me the torque tube rear end, what is it and when upgrading your rear end are you just talking the innards of the pumpkin or the entire rear axle? also what about drive shafts...what is an open drive line as i have heard it referred to, is that not the same as what is in a rear wheel truck today?
*UNDER CONSTRUCTION* 1953 Chevrolet 3100 1/2 ton-previously abandoned resto. My Project BoltI hate when people leave their brains at home. Seriously when did critical thinking and customer service go out the window? How about common sense and striving to go the extra mile? Idiots, surrounded by idiots it tell you.
| | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A torque tube is a sollid connection between the transmission and the rearend. There are no visible u-joints, and you would not see the torque tube spin while the vehicle is in motion.
An open drive rearend is what we are typically used to dealing with on modern rear wheel drive vehicles. A drive shaft with visible u joints can be seen spinning while the vehicle is in motion.
A torque tube rearend is much more efficient at transmitting the torque than an open drive rearend, so more of the available horsepower will make it to the wheels. This is in part because the tube prevents the axle from rolling and maximizes the effeciency of the joints.
The down side to the torque tube is parts availability. There are few gearsets that will fit in a torque tube rear, and most of them are not suitable for modern interstate driving. There are also few transmission choices to use with that torque tube rear. The torque tubes were designed for trucks rated for less than 150 hp... in the case of most 1/2 ton chevys with the torque tube, they were rated for less than 115 hp. When modern 300 + HP v8s are used in these trucks the torque tube transmission/and or rearend usually do not last very long. Most commonly one of the concealed u-joints breaks, as this tends to be the weakest link. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | The torque tube has an enclosed driveshaft. Torque tube rear. An open driveline has the driveshaft in the open. | | | | | Joined: Oct 2010 Posts: 111 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2010 Posts: 111 | Running a '69 Nova rear, 3.08 gears, 1" billet wheel spacers | | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I kept my old torque tube with enclosed propeller shaft. Rear gears were swapped out for Patrick's 3.55s. Old gears were shot anyways. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 |
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Silverado_9c3, that is not a stock rear end for an AD truck. | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | hmm..well thats good to know, I have only had this particular truck 3.5 weeks. next question I have is how might I find out what it is and what is it from?
| | | | | Joined: Nov 2007 Posts: 55 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 55 | That appears to be a GM truck 12 bolt, probably from the late 60's or early 70's. It should have 6 lug axles unless it's been converted to 5 lug.
Dave | | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | it is a 12 bolt housing and the number i found on it was NF3896838... I took the cover off and well it was dirt brown smelled ridiculous and all i could find was 386116N on the larger ring....
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | 12 bolt out of a 74 C10 on chassis engineering leafs.......dave can we get a pic of that set up Dyehouse12
| | | | | Joined: Dec 2010 Posts: 280 'Bolter | | 'Bolter Joined: Dec 2010 Posts: 280 | anyone know of an online souce to ID my rear end by its casting numbers?
| | | | | Joined: Jun 2005 Posts: 8 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 8 | That rear end looks similar to a 12 bole I have out of a '65 big block Impala. Look on the front side of the passenger side axle tube for a series of numbers and letters just above center usually but should be there under all the crude, dirt, etc. If it is a car rear I can help if U send the numbers/letters.
P.S. I have a '79 Camaro Z28 big 10 bolt 3.42 in my 1st series '55 with a 700R4 - works great though the 275R60s I had on 8" ralleys rubbed a little so went to a 255R60.
'55 1st series, '67 CST, '93 Sport Truck.
| | | | | Joined: Aug 2004 Posts: 1,067 Shop Shark | | Shop Shark Joined: Aug 2004 Posts: 1,067 | I'm using a Ford Dana 60 with 3.50 gears. I'm very happy with it.
52 GMC 3/4 ton pickup 68 Big Block Vette 68 455 Firebird | | |
