0 members (),
188
Mod | | | Forums66 Topics128,089 Posts1,056,441 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | There is a lot of talk about heaters lately. I didn't want to intrude on somebody elses thread with this question so here it is.
American Classic sells defroster ducts in original looking cloth or in plastic. For functionality, which would be better, longer lasting, and easier to install? The price is not that much different so I want to get the best of the two. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Vern - when you say "cloth" I must assume you are speaking of the wire bound type, correct? I think that is what I have on mine but never thought of them as cloth. I'd fear the plastic ones might get too hot and sag/stretch, etc. In any event mine seem to be OK but maybe the plastic is much heavier and better than I envision. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I think that is a yes on the wire-bound, part no. ME284 1947-53 Heater duct tubing, 1-3/4 inch diameter, cloth, $18.00 Each The plastic alternative is part no. ME284P 1947-53 Heater duct tubing, 1-3/4 inch diameter, plastic $15.00 Each
Like I said the price doesn't make a hill of beans difference. Would like to see opinions of those who have bought either or both.
I do know that with age the original style deteriorates and you can't remove and replace it very often without tearing it. Of course by the time it gets to that point it will likely be someone else who may not even be born yet who has to deal with it. | | | | | Joined: Feb 2006 Posts: 428 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 428 | FWIW, The cloth ducts were rotted away when I got my 52. I bought the plastic replacement ducts, and they are cheap and flimsy. As soon as I get the fresh air heater painted I will replace them with the cloth ones. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I got plastic generic duct through my FLAPS and it's served me well for 5 years now. The heater in my '38 doesn't get hot enough to cause any problems, I run a 160 deg thermostat.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .... I have NOT used this but I have seen a couple others use the aluminum flex like goes under the hood of a car....like what fastens under the air filter housings. They look pretty neat, and I think you can get them in the correct size at the local discount store. I think the price of those is about the same as what's mentioned above....except no shipping. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | I just put the wire/cloth ones in and they work great. They fit everything snugly to the point where I felt no need for any kind of clamps. The only "problem" I had was with the original metal passenger side defroster duct, the way it was made the opening was too large so I had to split the duct and use cloth tape to hold it on.
So I guess this is a case of an original part not being made correctly rather than the aftermarket part.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Thanks JimmiD, that's the kind of report I'm looking for. Did you get yours from ACTP or someone else? Tiny, I have looked and asked at all the local flaps and can't seem to find anything in 1.75" that will work. Alvin, that is what I'm using now on the passenger side. I can't find one long enough for the drivers side. Woody, you have destroyed that one-of-a-kind, original piece  Sounds like I need to go ahead and order the original style cloth. If it was good enough 57 years ago it should be good enough today. I was hoping for something better in the plastic but it sounds like it will have issues too. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Tiny, I have looked and asked at all the local flaps and can't seem to find anything in 1.75" that will work. If I recollect right they had to look in their book and order it in for me. It wasn't a stock item. I got it through Bumper To Bumper. I think I have a piece of it left over. How much do you need?
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Thanks Tiny. I need enough to do both defrosters in the 53. I think I will just order from ACTP. I need to find something else I need so I don't get hit with their minimum order of $20 policy. I meant to order it when I ordered the steering bearing but forgot. | | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | Woody, you have destroyed that one-of-a-kind, original piece  Man, I'm slipping here. What I MEANT to say is that I split the cloth duct. Since the original metal ducts are some of the only parts on my truck that weren't rusted to dust I'm not going to be the one to ruin them. | | | | | Joined: Dec 2009 Posts: 194 Shop Shark | | Shop Shark Joined: Dec 2009 Posts: 194 | Changed one last night, Auto Zone has a metal one that you can stretch and bend to fit about $20. Ain't origional, but works on my old 58 driver. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Thanks Hank, I'll check that out. | | |
