3 members (fonz8261, 5cameo8, Barry Martak), 114 guests, and 2 robots.
Topics128,089
Posts1,056,418
Members48,443
#69337 11/29/2006 4:46 AM
In the late '60's I worked on a friends Toyota Land Cruiser and I would swear it had a Chevrolet 6 cylinder engine in it....or it looked like a Chevy 6. This was the stock engine, he had not changed anything...was I sniffing too much glue!
Stuart
#69338 11/29/2006 4:53 AM
Very similiar motors, but parts are not interchangable.
If I remember right Toyota bought the motor from Chevrolet and made some changes.
#69339 11/29/2006 8:51 AM
Rumor has it much of the bottom end is interchangeable. The toyota version got a newly designed head. I'm not sure if that head interchanges with the 235 either.
Usually when the Japanese auto makers copy or take from the American auto makers they improve upon a good idea. That is not always the case.
Datsun coppied the british roadster concept in the 60s with the "Fair Lady". They copied the design so close to the Brittish design that it had the same electrical problems.
#69340 11/29/2006 6:34 PM
The early LC head had a combustion chamber just like the 235. The later LC head was modernized. I am not sure when, probably when smog requirements came into effect. I had a 74 LC and it had the modern head.
#69341 11/29/2006 6:43 PM
Something else I just thought of. In 1974 Toyota LC had a floor shift all syncro 4 speed trans. This trans looked like the older chevy truck 4sd. The mounting pattern was the same as a chevy. If I recall correctly the imput shaft is a little longer than a GM unit. I am not sure if this trans can be used without the transfer case, but it might be a consideration for someone who wanted an all syncro heavy duty trans. First gear is not as low as the GM first gear. With the 6 cyl I would always start in 1st gear. The LC had 4.10 diff. gears.
#69342 11/29/2006 7:03 PM
Hey, wait a second swingdaddy, I have a Nissan 311, and there are no Lucas components = no electrical problems. My second gear is a bit scratchy though.
#69343 11/29/2006 10:32 PM
It's funny this topic has finally come up. I sold my '78 Land Cruiser FJ40 to buy my '50 truck. I didn't realize how much they had in common until I started tearing into the truck.
The original LC engine was the F engine which was around 235 ci. In '75 they upgraded to the 2F which was 258 ci and ran that engine into the mid/late '80s. There was always a rumor around the LC community that Toyota had "stolen" the I-6 from Chevrolet. All I know is it's nearly impossible to kill a 2F on the trail.
I know the transmission in my '78 was an SM420, same as the transmission in my truck. The gears were 4.11:1 in the LC until '78. They changed to 3.73:1 in '79.
If you want more info or exact specs, look at www.ih8mud.com or www.sor.com
1950 Chevrolet 3100 "One Step Forward, Two Steps Back"
Webshot Photos
#69344 11/29/2006 10:44 PM
WOW, It looks like I wasn't sniffing as much glue as I thought...great info on this engine.
Stuart
#69345 11/30/2006 12:18 AM
Wow a metric stovebolt.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
#69346 11/30/2006 1:34 AM
That's it exactly. I had to make a stop at the store when I bought my truck because I didn't have any SAE wrenches. Everything in my toolbox is metric. The Cruiser even has timing gears, just like the truck.
And the word "J**P" is to Cruiserheads as "F@%D" is to Stovebolters. (It's those 4 letter words....)
Webshot Photos
#69347 11/30/2006 3:50 AM
tlorber
I was wondering if somebody was going to call Shannanagans on me!
#69348 11/30/2006 4:26 AM
I gotta say I do like jeeps but th tail gate on my S-10 says, "Yup your right I just don't get the jeep thing".
user
I
I Offline
The early Land Cruiser did have a copy of the 235 Chevy engine. Word has it that Chevy shared the spec info. with Toyota. I also hear that some of the parts are interchangable.
Just today I saw an old Land Rover. I talked to the owner and he said it was a 1964. He didn't know what engine it had so I looked at it. It looked just like the Chevy 250!! Ran well too.
Twenty five years ago or so as a young gun, I worked on one for a friends girlfriend. I id'd the engine as a chevrolet 250 and proceeded to fix and tune it up for her. Until now I had just assumed somebody swapped the Chevy engine into it. I must have done it right though, she never complained about the way it ran after that.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
I
I Offline
Hey 53monster, I like your truck. How's it coming along?
but
i have seen a 292 installed in a LAND ROVER
WHOLE different thing
the land CRUISER from Toyota is an EXCELLENT inline
but the old 4 banger found in old LAND ROVERS was junk
Jim & Caroline
Thanks Iron clad, It coming along, I managed to scrape it enough together to enter in a show this past weekend without a bed.
1953 Chevrolet 3600
I
I Offline
So apparently the Land Rover had an option of a 4 banger or a 6?
I know that the Land Rover I saw today had a 6 that looked just like the Chevy 250. Of course that dosn't mean it was stock though. (But I believe it was.)
Back in the 70's there was a company in the Los Angeles a Called Chevyota in which they did conversions with the 283 cu. Chevy engine for more power. There are a few around here running 350 cu. Chevy's with big Gumbo Mudder type tires too.
62Blue
Don
62Blue
62Chevy in progress
You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
The early Toyota L6 "F" engine, used 1955-74?, is not a copy of the Chevrolet 235 entirely, but a similar head and combustion chamber design but "scaled up" to the larger G.M.C. block dimensions but few interchangeable parts. Not "stolen", manufactured under license.
The later F updated the head design to parallel valves, and finally to 12 port.
No, the Toyota head doesn't fit either engine: too big for the 235, and the water, bolts, oil, etc. don't line up for the GMC.
