3 members (Jay R, 5cameo8, Barry Martak), 145 guests, and 2 robots.
Topics128,088
Posts1,056,416
Members48,443
#69181 11/26/2006 6:25 AM
Junior Member
Junior Member
I'm new to chevy engine rebuilding. I'm going to be building a 383 stroker for our 53 1-ton panel truck. I've built quite a few engines over the years but never a chevy small block. Anyone have any suggestions on what would be a good book(s) to buy for building the 383 stroker?
Thanks!
Brad
#69182 11/27/2006 2:02 AM
Junior Member
Junior Member
Haynes gives some pretty descriptive instructions.
#69183 11/27/2006 1:01 PM
Junior Member
Junior Member
52friend, thanks for the reply. I'll check out the Haynes manuals at the local parts store.
Brad
#69184 11/27/2006 5:07 PM
"How to Rebuild the Small-Block Chevrolet" by Atherton & Schreib. I got my copy off Amazon. Another good title is "John Lingenfelter on Modifying Small-Block Chevy Engines" also purchased off Amazon.
Daily Driver 63 C-10 LWB Fleetside
#69185 11/27/2006 7:21 PM
I have read several of these books and found one by David Vizard that gives some real good details of building a smal block chevy on a budget. Here is the link to the book that I highly recommend if you plan on building any performance SBC.
http://www.amazon.com/Build-Perform.../105-0969225-4896454?ie=UTF8&s=books
#69186 11/28/2006 1:41 AM
bkahler,
I'm not aware of any books that describe a specific build for the 383 but I may be wrong.I'm in the process of bulding a 383 if I can be of any help.I can share what I'm building if you would like.
In the works 2006 GEN III 6.0 /4L80E/ 205 New process,A/C and power brakes .
#69187 11/28/2006 4:08 PM
I don't think David Vizards book will disappoint you.
#69188 11/28/2006 9:40 PM
The books that I would recommend are above. I do recommend using the loger 350 rod over the shorter 400 rod. You need to by special 383 pistons with a raised pin but well worth it.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
