3 members (Hotrod Lincoln, MickeyP, Brian Moore), 44 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#68886 11/20/2006 4:33 AM
Junior Member
Junior Member
hi..
is there a hand crank for a 51 chev 235?
if so where can a get one?
paul
#68887 11/20/2006 6:41 AM
Canada5window,
This is just a guess, but I will say no. The crank pulley 'might' have the ears required for a crank, but I think the radiator needs a special pass-through to access the pulley.
I think '51 was into the modern era in the hand crank game. Watch me be all wet! eek
Stuart
#68888 11/20/2006 3:48 PM
Ex Hall Monitor
Ex Hall Monitor
If your truck is supposed to have one there should be a hole in the lower core support matching the shape of the crank. I'm with Stuart in that I don't believe a 51 had a hand crank. I guess that means if he's all wet I'll need a towel too.
#68889 11/20/2006 7:12 PM
My 52 has a the hole and pulley for a hand crank.
#68890 11/20/2006 7:52 PM
"My 52 has a the hole and pulley for a hand crank."
So does my '52.
Steve
'49 3800
'52 3600
'57 3100
#68891 11/20/2006 8:37 PM
Ex Hall Monitor
Ex Hall Monitor
Hey Stuart, do you have a towel I can borrow? grin
#68892 11/20/2006 8:42 PM
Tiny, I have a dozen coming FedEx! I'm still wondering if this might be a carryover from earlier times.
For this crank system to work, there must be some route through the grill, and maybe some outboard support for the crank.
Soaking-Stu
#68893 11/20/2006 8:52 PM
2 Offline
Paul, the 51 was set up for a hand crank. You want to check the harmonic balancer to make sure that it has the proper lug hole in it to allow the hand crank to release when the engine kicks. There is a possibility that the balancer was replaced in the past. If you are trying to hand crank it over prior to starting you can pull the plugs and use the fan as a crank or pull the pan off of the fly wheel and use a pry bar or screw driver to turn it over.
Tom
#68894 11/20/2006 10:26 PM
Welcome. American classic lists the hand crank for 1936-1953 and I think all A.D. trucks have the hole in the lower splash apron for it. The crank actually goes under the radiator. As mentioned the balancer needs to have 2 "fingers" to grab the crank. If you're engine was replaced with a later one the hand crank won't work. They are actually quite dangerous so if you just want to turn it put 2 bolts in the threaded holes in the balancer and rotate it with a prybar. Good luck. Crank is at the bottom of this page:
http://www.americanclassic.com/asp/...&iyear=1952&ytype=to&exyear=
Curt B.
You Tube
#68895 11/21/2006 12:28 AM
The balancer on my '55 has the lugs for a hand crank, too. There's not any clearance under the radiator to use one, though.
Bill Burmeister
#68896 11/21/2006 1:54 AM
Yup my 53s got one to, but darn, that starter works so well on its own...
Jeff
My 1953 Chevrolet
1947.1 Gallery
#68897 11/21/2006 2:11 AM
Be sure to use the arm that you won't need for a while if you actually want to use the hand crank. Or am I confusing the method with a F*#@.
#68898 11/21/2006 3:41 AM
My 53 has the proper set up for the crank, but have not run across one yet, if I do, I will buy it, because it was an option that I would like to have.As far as "kick-back" can't happen because the way the ears are tapered on the ballancer. Will proabily make my own out of some 3/4" cold roll round steel.
#68899 11/21/2006 4:54 AM
Junior Member
Junior Member
Hi and thanks for the info and humor...great stuff!
My 51 has a slot hole for a crank, I just wanted make sure that it was for a crank....
I will use the suggestions for turning it over without the starter, first...just to make sure everything is freed up....Again thanks to you all for your suggestions and help....
Great resource centre....
paul
#68900 11/21/2006 7:16 AM
I have the original crank for my '46, and I only use it when I adjust the points.
My starter works too well.
#68901 11/24/2006 3:42 PM
Apprentice
Apprentice
I believe that there was an additional sheet metal support that the crank ran thru that was attached to the center hole on the inside of the bumper.
#68902 11/24/2006 7:03 PM
Junior Member
Junior Member
Beav said: "kick-back" can't happen because the way the ears are tapered ......
hmmmm... sounds like you've never actually tried to start an engine with a hand crank...
trust me, it will kick back and if your arm is in the way.... OUCH ! be careful !
#68903 12/16/2006 6:23 AM
Quote
I agree, I have 1 that I actually found stuck under the seat in my "51" 3/4 ton and wondered what it was at first. I have never used it other than to check and see if it fit. First you have to get down on the ground in front (as it goes in under the bumper, easy for all of us to do, LOL) then to try to crank it over, and remove it from the hole after you get it started without accidently hitting anything on the way out. I just keep it for looks and may fix it for shows only when I figure out how I want it. Oh, I do like to eat and would hate to loose any teeth with it either.
Collecting is fun, as long as momma enjoys riding in them.
