1 members (stlcardinalsguy),
115
Mod | | | Forums66 Topics128,195 Posts1,057,374 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | So I've blasted all the parts, the spreaders, springs, shoe guides, and bunch of pieces I don't know the name of! Pretty much everything inside the drums.
These pieces didn't look painted before - should I paint them now? Were they treated before I blasted them?
Mark | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Those parts would have been raw metal. You can paint to protect them but it really wouldn't matter.
Bruce | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...I've notices a lot of the "hardware kits" are painted these days. I guess no particular reason but I do paint mine. If I live long enough to have to redo them then the parts will clean up like new....in a jiffy! | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I think after the blasting they will rust pretty quickly. I painted my links with Cast Blast, the springs black and the backing plate black. With all the trouble that you go to it is nice to have a good looking assembly when you are done. | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | Agreed - I'll givem a shot. Take a few pics and know that they're pretty behind the drum! | | | | | Joined: Apr 2006 Posts: 453 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 453 | I painted mine...No really need to, I just wanted them to look good! | | | | | Joined: Oct 2009 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2009 Posts: 46 | I`m doing my brakes right now and I painted all the inside parts White so it is easy to see every thing. The out side is going Black.
Gerry | | | | | Joined: Sep 2010 Posts: 575 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 575 | I`m doing my brakes right now and I painted all the inside parts White so it is easy to see every thing. The out side is going Black.
Gerry Gerry! Get some pictures up! | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I believe that when they redo brake parts they use a water base paint on them. I paint mine with any leftover colors I have. I like gold shoes and black springs and silver levers. | | |
