1 members (stoveboltgator),
218
0
Mod | | | Forums66 Topics128,048 Posts1,055,540 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I have a seized motor from sitting up over time. Does anyone know of any shortcuts to getting a motor turning again. I know a few but Was hoping for other ideas. I have heard of pouring Marvel mystery oil or PB Blaster in each cylinder and letting it sit for a while. Any cool ideas would be great? | | | | | Joined: Aug 2009 Posts: 295 Shop Shark | | Shop Shark Joined: Aug 2009 Posts: 295 | Myself I would use Kroil. Have heard of all sorts of stuff used though from engine oil to diesel or gasoline.
Let sit for while LEAVE SPARK PLUGS OUT or put em back in LOOSE then remove before turning.
Then get wrench and attempt to turn GENTLY first one way then the other. I say gently since you do not REALLY know what the problem is. If just stuck rings you might be OK to get it to rotate. Think I would be tempted to take the head off and have a look see.
Should also make double sure transmission is not jammed. Look for obstructions to ensure flywheel is not jammed. Dan Bentler | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | Acetone and Atf mixed up. Good stuff.
| | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I have heard transmission fluid before. Acetone mixed I have not that seems like a great idea. | | | | | Joined: Dec 2008 Posts: 899 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 899 | Acetone and Atf mixed up. Good stuff. I heard this was the best, 50/50 mix. And Kroil the next best.
Brian 1955.2 3100 Truck The older I get the more dangerous I am!!!!! | | | | | Joined: Jul 2005 Posts: 595 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 595 | ATF/ACETONE mixture is hard to beat! | | | | | Joined: Feb 2005 Posts: 469 Shop Shark | | Shop Shark Joined: Feb 2005 Posts: 469 | The acetone will thin the oil and it also eats on the carbon that has built up behind the rings. Once free be sure to drain the crankcase as all of the stuff you pour into the cyinders will end up there. Remove the valve cover and check for stuck valves as they can lead to bent push rods and other problems. | | | | | Joined: Jan 2005 Posts: 305 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 305 | also once it turns over make sue all pushrods are oilling after start up
ya I know a few rednecks.Thay all drive chevys to, Proud member of the Old Dominion Stovebolt Society AND A MARINE trucks range from 1942 1/2 ton to 1965 fire engine
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Not to hijack this thread but I have never ever seen any of this stuff (Kroil, PB blaster, WD 40, Knock-R-loose, MMO) actually work. Am I alone on this? ATF/Acetone just might do the trick as well as other home brews but the commercial stuff I think is snake oil.
Weeds | | | | | Joined: Sep 2009 Posts: 105 Shop Shark | | Shop Shark Joined: Sep 2009 Posts: 105 | I say this because I had a case of atf and a few gallons of acetone. I had a badly plugged up Rochester model B. I submerged it in a 50 50 mix for about two weeks. When I pulled it out, butterfly's were turning and the passages were clear. I also use it on siezed marine engines with great success. The trick is to periodically shake the mixture to keep it mixed up.
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Weeds, I've used the Kroil on badly frozen 46 engine but I was in no hurry. All in all it took me 6 weeks but it freed up..... but, I had one that after weeks of Kroil, marvel mystery, half this and half that I ended up pulling the heads and taking a piece of firewood and hitting the tops of the pistons to finally break it loose....... depending on how bad one is stuck, and the product used is what everyone things is the best!! | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I have used PB blaster many times on motorcycles and other small engines that have set up a long time. But larger bore engines are different I would assume. | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | I have used a piece of firewood myself to free up a motor. That was pretty tough but def the quickest way. | | | | | Joined: Sep 2009 Posts: 296 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 296 | Hook it up to another truck, put it in gear, depress clutch, have other truck slowly take off and periodically pop the clutch.
It works but I would put a little oil in each cylinder before I tried this.
-Patrick 1953 Chevrolet 3100 261 / 4-speed / 4:11 / Commercial Red
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | | | | | | Joined: Aug 2010 Posts: 105 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 105 | Well, after two weeks with marvel mystery oil and PB blaster in each cylinder the motor rotated freely with one hit of the starter this morning. Now to solve the spark issue because there is no spark. | | | | | Joined: Feb 2004 Posts: 29,756 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,756 | Hook it up to another truck, put it in gear, depress clutch, have other truck slowly take off and periodically pop the clutch. That's a good way to break an axle, trash the transmission, or bend a bunch of connecting rods. If it won't free up with penetrating oil and a long pry bar on the flywheel teeth, take it apart! Jerry
| | | | | Joined: Sep 2009 Posts: 71 New Guy | | New Guy Joined: Sep 2009 Posts: 71 | Ditto...I had to finally take mine apart with a log. A little strange hitting a cylinder head with a log and sledge hammer, but curiously fun too. | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | | | |
