1 members (SandraD), 56 guests, and 5 robots.
Topics128,021
Posts1,055,355
Members48,420
#678757 09/19/2010 2:46 AM
I was trying to clean my speedometer on my 46 pick up and broke the needle. Can anyone tell me where to try to get one.
Monroe McKill
Here you go.....and other vendors in the links section will have it as well.
http://www.oldchevytrucks.biz/34_46/full.asp?page=123
If you face is not that good you may want to consider a vinyl refacing kit. They have worked well for me over the years.
Riding in the Passing Lane
I've never been able to get the old needle off the shaft without breaking the shaft.
1972 Chevy c10 Cheyenne Super
Thanks. I will check the shaft first then hopefully order.
Monroe McKill
I use a gentle twisting force in a counter clockwise direction while I pull up. This has never failed for me. Sometimes when taking delicate things apart, I will warm them up with a hair dryer first.
1951 1 Ton Completed
The commonly available "speedometer needles" are just a cover that slips over your broken hub. Don't make the mistake I made and toss out your broken hub hoping to attach the new "needle" later.
Chuck
wrenchbender, I just did the same thing with mine a couple days ago. What can I do now? What did you do?
Hookalatch, your exactly right. Those needles go over the old hub. If I had known that I wouldnt have broken mine trying to get it off!
