2 members (Gib70, Tronman),
117
Mod | | | Forums66 Topics128,042 Posts1,055,509 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | I was trying to clean my speedometer on my 46 pick up and broke the needle. Can anyone tell me where to try to get one.
Monroe McKill
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Here you go.....and other vendors in the links section will have it as well. http://www.oldchevytrucks.biz/34_46/full.asp?page=123If you face is not that good you may want to consider a vinyl refacing kit. They have worked well for me over the years. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I've never been able to get the old needle off the shaft without breaking the shaft. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2010 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2010 Posts: 54 | Thanks. I will check the shaft first then hopefully order.
Monroe McKill
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I use a gentle twisting force in a counter clockwise direction while I pull up. This has never failed for me. Sometimes when taking delicate things apart, I will warm them up with a hair dryer first. | | | | | Joined: Apr 2009 Posts: 554 'Bolter | | 'Bolter Joined: Apr 2009 Posts: 554 | The commonly available "speedometer needles" are just a cover that slips over your broken hub. Don't make the mistake I made and toss out your broken hub hoping to attach the new "needle" later.
Chuck | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | wrenchbender, I just did the same thing with mine a couple days ago. What can I do now? What did you do? | | | | | Joined: Apr 2006 Posts: 136 Shop Shark | | Shop Shark Joined: Apr 2006 Posts: 136 | Hookalatch, your exactly right. Those needles go over the old hub. If I had known that I wouldnt have broken mine trying to get it off! | | |
