1 members (Bill Hanlon), 111 guests, and 2 robots.
Topics128,162
Posts1,056,924
Members48,458
#670254 08/14/2010 12:42 AM
Hey guys - looking for advise on removing windshield crank assembly. Mine needs to be repaired (or replaced) and I am looking for a way remove the old unit. Thanks in advance for your help!
Start by soaking all the pins and bolts with your favotite lube spray. Do this for a few days before going after the assembly. As far as remember, its bolted under the dash with a couple of 5/16" screws and nuts, the handle has a screw in it, and the windshield has a pin in it. Not much to it other then being under the dash.
Joe
You do know you have to take the dash off right ????
1938 Gmc 1/2 ton
Oh man - I was hopin' that would not have to happen!! Looks like this will be a winter project. Thought there might be another way to remove that assembly. Thanks for the info!
I have removed and reinstalled the one on my 37 1/2 ton pickup without removing the dash.
tcox you do know all it takes to get the dash off are the 4 bolts (2bolts and nuts on each side) lift up a little bit and pull back (not hard or far)and you should be able to access the bolts you need to get to. It might be a 20 minute job at most. Oh don't forget to unscrew the crank handle first. Good luck
1938 Gmc 1/2 ton
Inquiring mind want to know
1938 Gmc 1/2 ton
Yes, it does need to be loose, but, as I stated, the windshield crank mechanism can be removed without removing the dash.
Add me to the list of doing it without the dash out. Mine is a 37 but same as the 38. You have to be a bit flexible but it will come out without taking the dash out.
I'd almost bet the two screws holding the mechinism under the dash will come loose easier than those 4 dash screws. Those suckers can be a booger. I finally gave up on one dash and ground the heads off!! (should have welded a nut to the top of them!)
On those two screws under the dash be sure to use a thick wide blade screwdriver so you don't booger them up....or at least thats what mine had.
Authorized Pest
Authorized Pest
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Helps a noob like me - got a real nice 38 and do not want to booger it up. Figgerd I'd ask before I jumped in. Thanks for all the replies!
