| | | Forums66 Topics128,162 Posts1,056,933 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Hey guys - looking for advise on removing windshield crank assembly. Mine needs to be repaired (or replaced) and I am looking for a way remove the old unit. Thanks in advance for your help! | | | | | Joined: Feb 2000 Posts: 5,229 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,229 | Start by soaking all the pins and bolts with your favotite lube spray. Do this for a few days before going after the assembly. As far as remember, its bolted under the dash with a couple of 5/16" screws and nuts, the handle has a screw in it, and the windshield has a pin in it. Not much to it other then being under the dash.
Joe | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Hey guys - looking for advise on removing windshield crank assembly. Mine needs to be repaired (or replaced) and I am looking for a way remove the old unit. Thanks in advance for your help! You do know you have to take the dash off right ????
1938 Gmc 1/2 ton
| | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Oh man - I was hopin' that would not have to happen!! Looks like this will be a winter project. Thought there might be another way to remove that assembly. Thanks for the info! | | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I have removed and reinstalled the one on my 37 1/2 ton pickup without removing the dash.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | Oh man - I was hopin' that would not have to happen!! Looks like this will be a winter project. Thought there might be another way to remove that assembly. Thanks for the info! tcox you do know all it takes to get the dash off are the 4 bolts (2bolts and nuts on each side) lift up a little bit and pull back (not hard or far)and you should be able to access the bolts you need to get to. It might be a 20 minute job at most. Oh don't forget to unscrew the crank handle first. Good luck
1938 Gmc 1/2 ton
| | | | | Joined: Jan 2008 Posts: 159 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 159 | I have removed and reinstalled the one on my 37 1/2 ton pickup without removing the dash. Inquiring mind want to know
1938 Gmc 1/2 ton
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | Yes, it does need to be loose, but, as I stated, the windshield crank mechanism can be removed without removing the dash.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Add me to the list of doing it without the dash out. Mine is a 37 but same as the 38. You have to be a bit flexible but it will come out without taking the dash out.
I'd almost bet the two screws holding the mechinism under the dash will come loose easier than those 4 dash screws. Those suckers can be a booger. I finally gave up on one dash and ground the heads off!! (should have welded a nut to the top of them!)
On those two screws under the dash be sure to use a thick wide blade screwdriver so you don't booger them up....or at least thats what mine had. | | | | | Joined: Apr 2004 Posts: 5,090 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,090 |
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Aug 2010 Posts: 255 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 255 | Helps a noob like me - got a real nice 38 and do not want to booger it up. Figgerd I'd ask before I jumped in. Thanks for all the replies! | | |
