8 members (‘37ChevyPU, Hotrod Lincoln, Otto Skorzeny, CuzzFuzz, Shaffer's1950, SlimSix, TrknGMC, 1 invisible), 81 guests, and 3 robots.
Topics128,139
Posts1,056,451
Members48,441
Looking for some experience here...I have a stuck engine, I have time to let it sit. When I say time I mean like over the winter. I have heard of people using diesel fuel, automatic transmisson fluid and kerosene to put in the engine instead of oil and in the spark plug holes. Is one of these better than the other or is there something better?
Thanks in advance!
Chevman
I would definately use a rust penetrant as the soaking agent then add some lubricant as it works free. I use BG's In-Force as a penetrant but it's commercial grade stuff so finding it may be difficult. Go to dealerships and independent shops, they may sell you some,
Scott
Oh, Chevman, I see you're from my neck-of-the-woods. If you ever come to Cedar Rapids, I'll give you a can.
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
use some automatic tranny fluid in the mix it will free up anything given time and heat the side of the block every now and then
A stuck engine is not always due to a piston stuck to a cylinder. Have you verified that you have no dropped valve or a stuck starter, etc?
I just got my 56 Chevy 2 ton home a week ago. My engine is stuck too. I have the plugs out and I've got clear plastic tubes stuck in each spark plug hole. I plan on soaking it until it comes loose also.
Would sugest pulling the pan at least to see what you could see, gasket probably needs replacing anyway. rusty cyls, frozen bearings etc. a lot easer to inspect from the bottom.
WD-40 gets my vote. It's a reasonable penetrant, has pretty good lubricating qualities, and you can buy it just about anywhere in 1 gal cans. Pour some in each cylinder and let it sit for a while...
Daily Driver 63 C-10 LWB Fleetside
It's in the Archives
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=22;t=006231#000000
Larry
I don't own a vehicle that isn't old enough to drink.
All of the above tips sound pretty good. One thing more you might want to check is the valve train. Most of the time you will find stuck valves. When the motor is free remove the valve cover make sure all of the valves move freely or you could suffer push rod damage. Also you should check the fuel system such as rust and bad gas in the tank old leaky fuel pumps and rotten rubber hoses.
Sounds like Kroil has had several successes and is worth a try. I will get some and give it a try.
Thanks to all!
I like KC Masterpiece and a little bit of Tapa Tio and Coca Cola. Uh the engine... ATF or Marvel Mistery Oil, or a combination.
Good Luck
Junior Member
Junior Member
[QUOTE]Originally posted by chevman:
[QB] Looking for some experience here...I have a stuck engine, I have time to let it sit. When I say time I mean like over the winter. I have heard of people using diesel fuel, automatic transmisson fluid and kerosene to put in the engine instead of oil and in the spark plug holes. Is one of these better than the other or is there something better?
Thanks in advance!
I worked on 41 Caddy motor a few years back. I put Marble Mistery Oil in it and it worked. It will take at least four weeks but the longer the better.
Once I had it some what moving...I put the Caddy on first gear then pulled it with my other truck...It really worked then. Good luck.
You will prob. want to freshen up the engine any way, so I would remove the head and pan. Squirt them with a good penatrent use a wooden dowl and a mallet to knock the piston tops with and soak it again. Continue this action till free.
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson"
I like Kroil from Kano laboratories. It is the best penetrant I have ever used. A friend of mine has been using it for years at his motorcycle shop and his personal restoration projects. You squirt it into the cylinders and leave it sit a few days. The company also sells plenty other excellent products. It has put all other stuff on the market to shame.
1937 Chevy 1/2-Ton
