3 members (BC59, Leo, Hotrod Lincoln), 119 guests, and 3 robots.
Topics128,134
Posts1,056,410
Members48,441
I have my both door cleaned and ready for primer, I was able to remove one ventilator and other one is stuck. I checked the manual and manual says "remove channel attaching bolt"
http://picasaweb.google.com/lh/photo/z-laEP99Fpyzzml8vjv5wMlOYeYVGd2ZPqPuwtMBM0o?feat=directlink
Now do I have to access through the lower opening where we bolt the door mount brackets or is it accessible from outside. I will really appreciate your inputs. Looks like when project is hot, one or two questions I pop every day. Thanks for taking time
Ganesh
You have to stick a ratchet (1/2" socket) up through the door hinge cover opening it is up there about 10" use extentions so your socket handle is in the door opening so you can turn it. If you can hit it with some penetrating lube from the top I would advise it. If it is stuck it will twist the end of the venti-pane channel they usually don't break they just twist the channel. Look at the one that came out the weld nut on the bottom is what you are breaking the bolt out of, it is not uncommon to find them in the bottom of the door having fallen out over the years, was the first one missing?
Yes, through the access panel. If memory serves, it is a 1/2" socket and about 10" extension needed.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Thanks guys, yes the first one didnot have anything, I just pulled it and it came out no problems, look like I have to work hard on this one. Can I just paint without removing?
Ganesh
I just did this on my 51. Along with what others have suggested I found it useful to get a small automotive mirror on a telescoping handle. It makes it easier to see up in the door and you don't have to lie on your back. I had to spray some penetrating oil on mine and let soak for a couple of days before they broke loose.
Chris
Boy, do I feel stoopid... what the heck is a door ventilator? Are you talking about the vent window?
Woody
Your Brother in Bolthood
My 1951 half-ton 'Ol Red
Door Art Collection
Woody door ventilator is what they refer for vent window in Chevy Manuals
Ganesh
I guess I fell asleep during that part... grin
Woody
Door Art Collection
...don't feel bad Woody. I had to click on the link to make sure what we were looking at!!
smokey truck, you CAN paint without taking them out but if the rubber is bad around the wing vent then I'd pull it out and put some new rubber in it. Its all available as a kit from most vendors. Steele Rubber products is the best but it is also pricey. If its good then I'd proceed.
It is amazing how much easier working on these old trucks can be when you use a factory assembly manual.
~Jim
AiN'T it the truth!
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
