5 members (RoadsScholar, dt235sd, JoergK., carbking, 1 invisible), 359 guests, and 5 robots.
Topics128,164
Posts1,057,079
Members48,463
#656232 06/20/2010 11:42 PM
I just purchased a very rusty (mostly surface rust) 1952 Chevy 1/2ton. The truck is 100% complete and original. It even had the windsheild eyebrow or whatever you call it.
So, I am new to the old truck scene, but not new to car work or restorations. I plan on doing an original restoration with a couple possible exceptions (I could be talked out of these): disk front brakes for safety, chrome grill, IPE bed for durability.
The truck even has a factory blank off plate where the radio would have gone. No one ever installed a radio in this truck!
Welcome to stovebolt. If you have any questions, Ask away, there are a lot of good folk here willing and able to help.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
Leo Offline
Moderator
Moderator
Hey David, I will wish you luck. Welcome to the site. Those visors certainly add to the character of the truck. Having good brakes is always a good idea, I sometimes second guess my decision to stay with the single action master cylinder and the drum brakes. I hope you enjoy the restoration process, you can always ask whatever you need to know.
Leo
Welcome David, hope you enjoy your 52 as much as I enjoy mine.
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Hi David,glad you could join us.
Sounds like you've found yourself a good original,'unmolested' truck.
The folks here will keep you on the straight and narrow.
Good luck and don't forget some pics.
Jock thumbs_up
More pix on Flickr.
Welcome Davis to the clan!
I think at the same way of "1953 panel", the original brake system is the good enough if you keep your truck original. Mine works great.
Don´t forget to show us the progress of your truck, we love PICTURES.
THANKS
Alfonso
Well, I went out today (truck is still in field of PO) to take a few more photos of the truck and to get the serial number off the engine. It looks like the engine is the original 216 (KBA) from 1952.
I also notice the heater was a simple box with an "Arvin" plaque on it. Being that the truck is in Texas, it might have to go.
I will probably keep the original brakes unless the cost to rebuild them exceeds the cost of adding disks.
I will post pictures if I figure out how.
Dave, welcome to the bolt and good luck on the restoration. There are a lot of Bolters in and around Texas so your in good company. Thanks for the pics.... and oh, your truck looks great especially compared to what some of us start with smile
U
U Offline
wish you all the best with your restoration , disc brakes I think would be a good idea as its other drivers that you need to watch out for , original braking system was good for 1952 not for 2010 conditions , I recommend a supplier near you ( at least the same state) http://www.americanclassic.com closer to you than me
regards
andrew
Good luck with your new ride. The guys/gals here like um all different ways so do it to your taste. Several very experienced "Bolters" in your neck of the woods so if you need help just holler!
Joy Offline
Wow, That is a very nice truck. I guess people use to talk to each other rather than listen to the radio. Even in my 50, the engine noises competes with the radio. Good luck and welcome to Stovebolt!
Nice truck David. Welcome
Looking good, welcome to the forum!
1963 Chevy C-10 Fleetside
1970 C-30 Dump Truck
2025 Silverado High Country 2500 Diesel
2012 Indian Chief Vintage serial #002 motorcycle
1946 Indian Chief, 1947 Indian Chief w/sidecar,2014 Indian Chieftain, 2015 Indian Scout
MJD Offline
Apprentice
Apprentice
David -- The Arvin heater was on a lot of trucks back then, we had a '49 Dodge pickup with that Arvin.
Also the radio delete plate was pretty common on the farm trucks around here, not many had radios at all, just basic trucks for working back then.
I wish you the best in your project, looks nice to see a complete truck and something still original. They really were great transportaion at the time !!
smile
mjd
Nice truck, I don't see what I consider rust. She looks pretty solid with just surface rust. I'm use to rust that people can fall through up here in Illinois. Nice truck!
Yes, mostly surface rust. The cab corners have rot of course, but otherwise very solid. Yes, I have come to realize the radio delete was very common, but I guess my main point was that no one ever installed a radio over the past 50+ years...to me, that is unusual.
Currently, I am in the process of cleaning out the work space and finishing up other projects so I can get started on the truck...maybe in a couple months when the weather turns a bit cooler here in central Texas.
