0 members (),
93
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 22 Apprentice | | Apprentice Joined: Jan 2010 Posts: 22 | I have a V8 with a 4 barrel quadra jet, the engine wont run unless I have the choke closed full otherwise it will sputter backfire then stall out, whats the problem here? Timing, or a clogged carb?
If the frame is Good then everything else can be fixed. 1930 Chevy 1/2 ton (Sold her) 1948 Ford f-5 (Shot her) 1951 Willys-Overland Wagon (Lost her) 1959 Chevy Apache Fleetside (Left her) 1956 Oldsmobile Super 88 (Drive her)
| | | | | Joined: Feb 2000 Posts: 203 Shop Shark | | Shop Shark Joined: Feb 2000 Posts: 203 | I'd say timing ... mostly because it's the easiest to check. How old is the timing gear? | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Fouled plugs from over choking. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Also, check for vacuum leak! | | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | X2 on the vacuum leak. Spray a little starting fluid around the base of the carb, vacuum junctions, etc. while the engine is idling and listen for the rpm's to increase, when/if you hear the engine speed up a little, you've found your problem. | | | | | Joined: Jan 2010 Posts: 22 Apprentice | | Apprentice Joined: Jan 2010 Posts: 22 | I sprayed around all the vacuum ports with no increase in RPM. This is an 56 oldsmobile Super 88 it was a government car kept on a Navy Base (Treasure Island) so it's been taken care of quite well the base closed in 91 and made its way to Michigan. By the looks of it the engine was rebuilt. The timing got out of wack when I put in a rebuilt transmission. I cant time it spot on with the engine running at such a high RPM kind of stuck here. I'm going to take the carb apart clean it with cleaner fluid and an air compressor and report back.
| | | | | Joined: Dec 2006 Posts: 1,464 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,464 | Could still be a vacuum leak - at the far end of the hose or device. Pull each hose off at the carb or manifold and put a little suction on and see if it holds. Sometimes the vacuum advance diaphrams will leak or if it has power brakes, could be a leak there. | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Check and see if it has a in carb fuel filter ,remove the inlet pipe and the fitting if that is cloged it will do the same thing.
Pete | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Also, hook up a vacuum gauge and see what it reads, should be 16 to 20 and a good tool to set timing etc.
Also if it was at T-I, some drunken sailor may have pee'd in the carb or worse.
| | | | | Joined: Apr 2010 Posts: 160 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 160 | [quote=Pete52]Check and see if it has a in carb fuel filter ,remove the inlet pipe and the fitting if that is cloged it will do the same thing.
And while you have the line off check fuel pump press and volume.
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I think the carb is full of water or dirt. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
