1 members (delky), 65 guests, and 2 robots.
Topics128,049
Posts1,055,740
Apprentice
Apprentice
I have a V8 with a 4 barrel quadra jet, the engine wont run unless I have the choke closed full otherwise it will sputter backfire then stall out, whats the problem here? Timing, or a clogged carb?
If the frame is Good then everything else can be fixed.
1930 Chevy 1/2 ton (Sold her)
1948 Ford f-5 (Shot her)
1951 Willys-Overland Wagon (Lost her)
1959 Chevy Apache Fleetside (Left her)
1956 Oldsmobile Super 88 (Drive her)
I'd say timing ... mostly because it's the easiest to check. How old is the timing gear?
Fouled plugs from over choking.
Also, check for vacuum leak!
1946 1/2-Ton Chevy
X2 on the vacuum leak. Spray a little starting fluid around the base of the carb, vacuum junctions, etc. while the engine is idling and listen for the rpm's to increase, when/if you hear the engine speed up a little, you've found your problem.
Apprentice
Apprentice
I sprayed around all the vacuum ports with no increase in RPM. This is an 56 oldsmobile Super 88 it was a government car kept on a Navy Base (Treasure Island) so it's been taken care of quite well the base closed in 91 and made its way to Michigan. By the looks of it the engine was rebuilt. The timing got out of wack when I put in a rebuilt transmission. I cant time it spot on with the engine running at such a high RPM kind of stuck here. I'm going to take the carb apart clean it with cleaner fluid and an air compressor and report back.
Could still be a vacuum leak - at the far end of the hose or device. Pull each hose off at the carb or manifold and put a little suction on and see if it holds. Sometimes the vacuum advance diaphrams will leak or if it has power brakes, could be a leak there.
Check and see if it has a in carb fuel filter ,remove the inlet pipe and the fitting if that is cloged it will do the same thing.
Pete
Also, hook up a vacuum gauge and see what it reads, should be 16 to 20 and a good tool to set timing etc.
Also if it was at T-I, some drunken sailor may have pee'd in the carb or worse.
1946 1/2-Ton Chevy
[quote=Pete52]Check and see if it has a in carb fuel filter ,remove the inlet pipe and the fitting if that is cloged it will do the same thing.
And while you have the line off check fuel pump press and volume.
Riding in the Passing Lane
I think the carb is full of water or dirt.
1972 Chevy c10 Cheyenne Super
