5 members (TPR57C, Bill Hanlon, Samantha, TooMany2count, 1 invisible), 149 guests, and 3 robots.
Topics128,186
Posts1,057,315
Members48,469
Can anyone help with pics of the throttle cable and links inside the engine compartment? Should be same for 60-63
http://s971.photobucket.com/albums/ae197/jon63c10
1963 c-10 shortbed stepside 427 BBC T16 HD 3 speed
1963 c-10 shortbed fleetside 348 "w" 1st gen big block & powerglide
It should be a rod and pivot set up, no cable until the 70's,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Ive got the choke cable installed, but the truck came with a throttle cable also...problem is it was removed before i got it. I bought a new one, but can't see how the darn thing installs. All i have is a hole in my dash next to ignition. Was hopeing if someone had some pics might help. 63 chevy 230/3speed
p.s.i have the rod/pivot set up and it works correctly. What was the throttle cable used for? Might sound retarded...I understand the choke cable, but was the throttle cable a poor mans cruise control?
Throttle cable was used a lot of times if you had a PTO set up on your truck. that way you could run the accessory without having to stay in the cab and press the accelerator.
