| | | Forums66 Topics128,187 Posts1,057,313 Members48,468 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Can anyone help with pics of the throttle cable and links inside the engine compartment? Should be same for 60-63 | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | It should be a rod and pivot set up, no cable until the 70's, Scott | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | Ive got the choke cable installed, but the truck came with a throttle cable also...problem is it was removed before i got it. I bought a new one, but can't see how the darn thing installs. All i have is a hole in my dash next to ignition. Was hopeing if someone had some pics might help. 63 chevy 230/3speed | | | | | Joined: Oct 2009 Posts: 426 Shop Shark | | Shop Shark Joined: Oct 2009 Posts: 426 | p.s.i have the rod/pivot set up and it works correctly. What was the throttle cable used for? Might sound retarded...I understand the choke cable, but was the throttle cable a poor mans cruise control? | | | | | Joined: Apr 2010 Posts: 436 'Bolter | | 'Bolter Joined: Apr 2010 Posts: 436 | Throttle cable was used a lot of times if you had a PTO set up on your truck. that way you could run the accessory without having to stay in the cab and press the accelerator.
