7 members (Cosmo, Shaffer's1950, Oswald, Wally / Montana, J Lucas, 2 invisible), 47 guests, and 1 robot.
Topics128,075
Posts1,055,918
Members48,429
#61588 06/10/2006 3:15 AM
Junior Member
Junior Member
Can I buy a new rear end gear that is of a higher ratio to my old truck will go around 65 MPH without it running so hard ??? 54' pickup original
54 chevy 3100
#61589 06/10/2006 3:32 AM
you may want to see if a 54 sedan rear end will work from a car donor. I think they will. I also know a 55 rear end will bolt into the housing on a 52 so you should be able to do it without spending a lot for some new gears. Some more guys will most likely chip in here that has the experience but I'm sure there is a swap available. Do a search in this forum and see what you come up with or check some earlier post from a week or two ago. I know its been discussed at great lengths.
#61590 06/10/2006 4:06 AM
What size truck do you have?
A 3/4 or 1 ton have interchangable differential parts from 1946-1972.
In the late fifties, sixties, and seventies, they made lower ratio (taller) gears in the 3/4 tons. You can get 3.73:1 and 4.10:1 off of those trucks that were originally equipped with automatics.
Usually.
If you're a half ton, check with the various vendors and Patrick's to see if the 3.55:1 gears are still available.
I would go with a gearing swap over an axle swap because the brakes that came with your truck are going to be better than the ones on a car axle.
#61591 06/10/2006 6:06 PM
Junior Member
Junior Member
Are you staying stock or are you willing to modify the rear end?
#61592 06/11/2006 1:10 AM
Junior Member
Junior Member
I would like to keep the rear end housing the same but put new gears in. This truck is a 1/2 ton 3100 short bed....
54 chevy 3100
#61593 06/11/2006 2:54 AM
Patrick's has the 3.55's and what used to be Chevy Duty was offering some in the 3.30 range, a 3.38 I think. Something I find amazing is that a fellow with a farm equipment repair shop near me has a 57 with an overdrive and a 3.08 rear end. This is a final drive of 2.16!! We did some repair to it and when I drove it back to his place the route had some rolling hills and I was amazed that it didn't lug down even 1mph going up the hills. The 235 in it is fresh and runs very well but I'm still surprised that it pulled so effortlessly without bucking or pinging.
Evan
#61594 06/11/2006 12:05 PM
I need to add one more thing--this would make a strickly driving vehicle, towing or loading would be out.
Evan
#61595 06/11/2006 7:42 PM
Junior Member
Junior Member
John I have a 52 1/2 ton and i put the 3.55:1 in my stock rearend and it will do 65mph easy on the highway and i got it from patricks.
_____
Ryan
Smoke Em if You Got Em
RYAN
#61596 06/12/2006 1:43 AM
Junior Member
Junior Member
Thanks Ryan, I will check out patricks...I'm new and never heard of Patricks but we'll find them..
Thanks!!
54 chevy 3100
#61597 06/14/2006 9:28 PM
Junior Member
Junior Member
John just go to patricksantiquecars.com or call this number for a free catalog.
Telephone
(520) 836-1117 (8 a.m. to 4 p.m. Monday-Friday/MST)
___________
Ryan
RYAN
#61598 06/15/2006 1:13 AM
You can usually find one cheaper in a salvage yard.
#61599 06/15/2006 1:20 AM
Quote
If you can find a torque tube style 3rd member in a salvage yard with 3.55:1 gearing, let me know where. Otherwise, you'l not only need the complete rear end, but also a transmission and a custom fit driveshaft. Plus, you'll have to do a little modification to your spring mounts and probably the shock mounts. I don't think you'll save much doing that, although you will have a lot more choices for transmissions and rear end ratios.
