1 members (tesa),
142
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#61588 06/10/2006 3:15 AM | Joined: Apr 2006 Posts: 11 Junior Member | | Junior Member Joined: Apr 2006 Posts: 11 | Can I buy a new rear end gear that is of a higher ratio to my old truck will go around 65 MPH without it running so hard ??? 54' pickup original
54 chevy 3100
#61589 06/10/2006 3:32 AM | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | you may want to see if a 54 sedan rear end will work from a car donor. I think they will. I also know a 55 rear end will bolt into the housing on a 52 so you should be able to do it without spending a lot for some new gears. Some more guys will most likely chip in here that has the experience but I'm sure there is a swap available. Do a search in this forum and see what you come up with or check some earlier post from a week or two ago. I know its been discussed at great lengths. | | |
#61590 06/10/2006 4:06 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | What size truck do you have?
A 3/4 or 1 ton have interchangable differential parts from 1946-1972.
In the late fifties, sixties, and seventies, they made lower ratio (taller) gears in the 3/4 tons. You can get 3.73:1 and 4.10:1 off of those trucks that were originally equipped with automatics.
Usually.
If you're a half ton, check with the various vendors and Patrick's to see if the 3.55:1 gears are still available.
I would go with a gearing swap over an axle swap because the brakes that came with your truck are going to be better than the ones on a car axle. | | |
#61591 06/10/2006 6:06 PM | Joined: May 2006 Posts: 10 Junior Member | | Junior Member Joined: May 2006 Posts: 10 | Are you staying stock or are you willing to modify the rear end? | | |
#61592 06/11/2006 1:10 AM | Joined: Apr 2006 Posts: 11 Junior Member | | Junior Member Joined: Apr 2006 Posts: 11 | I would like to keep the rear end housing the same but put new gears in. This truck is a 1/2 ton 3100 short bed....
54 chevy 3100
#61593 06/11/2006 2:54 AM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | Patrick's has the 3.55's and what used to be Chevy Duty was offering some in the 3.30 range, a 3.38 I think. Something I find amazing is that a fellow with a farm equipment repair shop near me has a 57 with an overdrive and a 3.08 rear end. This is a final drive of 2.16!! We did some repair to it and when I drove it back to his place the route had some rolling hills and I was amazed that it didn't lug down even 1mph going up the hills. The 235 in it is fresh and runs very well but I'm still surprised that it pulled so effortlessly without bucking or pinging.
Evan
#61594 06/11/2006 12:05 PM | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | I need to add one more thing--this would make a strickly driving vehicle, towing or loading would be out.
Evan
#61595 06/11/2006 7:42 PM | Joined: May 2006 Posts: 17 Junior Member | | Junior Member Joined: May 2006 Posts: 17 | John I have a 52 1/2 ton and i put the 3.55:1 in my stock rearend and it will do 65mph easy on the highway and i got it from patricks.
_____ Ryan
Smoke Em if You Got Em
RYAN
#61596 06/12/2006 1:43 AM | Joined: Apr 2006 Posts: 11 Junior Member | | Junior Member Joined: Apr 2006 Posts: 11 | Thanks Ryan, I will check out patricks...I'm new and never heard of Patricks but we'll find them..
Thanks!!
54 chevy 3100
#61597 06/14/2006 9:28 PM | Joined: May 2006 Posts: 17 Junior Member | | Junior Member Joined: May 2006 Posts: 17 | John just go to patricksantiquecars.com or call this number for a free catalog. Telephone (520) 836-1117 (8 a.m. to 4 p.m. Monday-Friday/MST)
___________
Ryan
RYAN
#61598 06/15/2006 1:13 AM | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | You can usually find one cheaper in a salvage yard. | | |
#61599 06/15/2006 1:20 AM | Joined: Aug 2005 Posts: 157 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2005 Posts: 157 | Originally posted by Gazim: You can usually find one cheaper in a salvage yard. If you can find a torque tube style 3rd member in a salvage yard with 3.55:1 gearing, let me know where. Otherwise, you'l not only need the complete rear end, but also a transmission and a custom fit driveshaft. Plus, you'll have to do a little modification to your spring mounts and probably the shock mounts. I don't think you'll save much doing that, although you will have a lot more choices for transmissions and rear end ratios. | | |
