| | | Forums66 Topics128,037 Posts1,055,467 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Does anybody know of a quick and easy way to get the inside handles off the doors. Mine are stuck on tighter than, well lets just say there stuck.
Charlie
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | They have a set screw underneath the handle arm. Align your long flat skinny screwdriver with the knob. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Charley, although they are probably gone a long time ago some handle will have a "cap-screw" in them. You back out the cap screw and then there will be another one that is tight and holds the handle on. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I drip a little PB Blaster in them sometimes if they are really stuck. They get pretty dry if they have never been off in 60 years. Once you loosen the screws they should come right off. They are splined but they are dissimilar metal types so they usually don't "weld" togehter. | | |
