8 members (Rusty Rod, TUTS 59, Peggy M, 3B, J Lucas, David Bush, Southerntruck, msmall), 122 guests, and 4 robots.
Topics128,065
Posts1,055,863
Members48,428
#604691 12/27/2009 6:51 AM
Where can I find a side-mounted spare tire rack, as well as the "cut-out" fender? I've got a 61 longbed stepside and I'd like to add a spare tire rack to "masquerade" the long, "blank" area of the bed between the cab and rear fenders. I've seen pics of trucks with them and have also seen then in the factory assembly manual, but can't seem to find either the rack or fender anywhere.
Good looking truck!
Put an ad in the "Truck Parts Wanted" forum and see what you come up with.
Larry
I don't own a vehicle that isn't old enough to drink.
Keep your eyes out for pick-up trailers with one on it. I think the fenders are the same back into the mid 50's (55 second series),
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
RJ Offline
61, you have mail.
RJ #604768 12/27/2009 6:40 PM
1 Offline
Yea that long bed sure could use a tire there.
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
Also note that per information in the following thread, the cut out fenders are different between the long bed and the short bed.
http://67-72chevytrucks.com/vboard/showthread.php?p=3528171
The short bed mounts the tire higher up, and the long bed fender mounts the tire lower since there is more space between the fender and the cab.
1960 GMC 1/2-Ton Pickup Truck
Updates in the DITY Gallery
Markeb #604838 12/28/2009 12:16 AM
That is something that I didn't know, this site has a lot of very knowelagable people that don't mine sharing.
You Learn more Listening than Talking
Too bad you're not closer as I have a fender you could have real cheap. I had the rack also but it sold fast but watch out for rusted out racks. If it can't be taken apart without the original bolts breaking than keep looking as they are out there
Markeb #605163 12/29/2009 4:24 AM
Sweet.. my build thread posted as a reference. :-)
Best way to tell the difference in the fenders is to compare the bottom of the cut-out with the wheel opening in the fender. The lower spare tire location on the long bed fender looks better, IMHO
Why not just build a tire holding rack and install the spare tire in the space using the present finder? Looks like there is enough space to do that. I once owned a 61 short-bed. It was one of the best trucks I ever had. Probably running around on the streets of Houston Tx to this day. I presently have a 62' in great shape and love it!
Green Machine
Edabbs #607298 01/05/2010 7:05 AM
Duh. Why didn't I think of that. I just measured the space between the cab and fender and yes, there's enough space!
Edabbs #609839 01/13/2010 11:22 PM
Not sure if this is waht your looking for but heres a link to ebay. http://cgi.ebay.com/ebaymotors/1955...torsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
1947 1Ton stepside
1962 K20 Fleetside
1962 C40 12' flatbed
1963 C10 Stepside
1963 C20 Fleetside
1965 C10 Stepside (Daily Driver)
1973 C20 Stepside fire truck
1973 C50 Utility truck Houston Power & Light
Wow...auction went for $135
