8 members (Hotrod Lincoln, DadsFirstPickup, Southerntruck, 32Fordpuchoptop, Ponchogl, 2-Ton, dt235sd, 1 invisible), 93 guests, and 1 robot.
Topics128,049
Posts1,055,674
#594085 11/20/2009 4:08 PM
I hope this is in the right forum, but does anybody know what years, makes and/or model key-start switches are a good fit for the 53 A-D truck. I have the original switch which is just on-off for the foot starter. i would like to get my ignition, glove box and doors all keyed the same. Also anybody know who sells them new or used?
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
If your switch and door lock is orginial they should be keyed for the same key. The glove box used another key.
You can take you tumblers to a locksmith along with the ignition key and have them keyed for that key.
OK, The ignition switch won't work, no key start. I am missing keys for any locks that I have unless you consider the ignition switch will work with a screwdriver.
1953 Chevrolet 3600
OK, take all tumblers to a locksmith and get all keyed for the same key.
The original question was what years do I look in for a switch that will work in the truck not what to do with the stuff I have that won't.
1953 Chevrolet 3600
.....I'm wondering the same thing but I believe I can find a "universal" start switch that will at leas resemble the original and then have a key cut using a chevy key blank.... I'm hoping!!
EDIT: I did this with my 37 but could never find a Chev key blank close enough to cut one tha would fit the switch... but no one knows but me!!
These "universal switches" do not look very original:
1947-59, key start, supposedly
vs
1947-59, foot start
Tim
No they do not look or act like originals, I am using one of the first link types and it sticks between on and start. Very bad for the starter. I would like to find one like this one that JimBow gave to deluxe54panel a couple years ago.
1953 Chevrolet 3600
this is the one, if it'll fit the dash hole - from American Classic
That's it, Thanks Squeeze.
Hey, Look what else I found there. Everything I want and need, I better start writing my letter to Santa.
1953 Chevrolet 3600
Apprentice
Apprentice
Okay, but how does it connect? Where do the three wires go from the ignition switch?
"FLY ARMY"
1953Av8tor
1953 Chevy 3100
"Airspeed, altitude and brains - two are always needed to complete the flight successfully"
Moderated by  ndkid275, Phak1
