7 members (Gdads51, Ponchogl, Brian Moore, TUTS 59, Hotrod Lincoln, Bill Hanlon, 1 invisible),
90
Mod | | | Forums66 Topics128,045 Posts1,055,528 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I hope this is in the right forum, but does anybody know what years, makes and/or model key-start switches are a good fit for the 53 A-D truck. I have the original switch which is just on-off for the foot starter. i would like to get my ignition, glove box and doors all keyed the same. Also anybody know who sells them new or used? | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | If your switch and door lock is orginial they should be keyed for the same key. The glove box used another key.
You can take you tumblers to a locksmith along with the ignition key and have them keyed for that key. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | OK, The ignition switch won't work, no key start. I am missing keys for any locks that I have unless you consider the ignition switch will work with a screwdriver. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | OK, take all tumblers to a locksmith and get all keyed for the same key. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | The original question was what years do I look in for a switch that will work in the truck not what to do with the stuff I have that won't. I hope this is in the right forum, but does anybody know what years, makes and/or model key-start switches are a good fit for the 53 A-D truck. I have the original switch which is just on-off for the foot starter. i would like to get my ignition, glove box and doors all keyed the same. Also anybody know who sells them new or used? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | .....I'm wondering the same thing but I believe I can find a "universal" start switch that will at leas resemble the original and then have a key cut using a chevy key blank.... I'm hoping!!
EDIT: I did this with my 37 but could never find a Chev key blank close enough to cut one tha would fit the switch... but no one knows but me!!
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | No they do not look or act like originals, I am using one of the first link types and it sticks between on and start. Very bad for the starter. I would like to find one like this one that JimBow gave to deluxe54panel a couple years ago. | | | | | Joined: Jul 2001 Posts: 3,887 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2001 Posts: 3,887 | this is the one, if it'll fit the dash hole - from American ClassicBill | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | That's it, Thanks Squeeze. Hey, Look what else I found there. Everything I want and need, I better start writing my letter to Santa.
| | | | | Joined: Mar 2009 Posts: 13 Apprentice | | Apprentice Joined: Mar 2009 Posts: 13 | Okay, but how does it connect? Where do the three wires go from the ignition switch?
"FLY ARMY" 1953Av8tor 1953 Chevy 3100 "Airspeed, altitude and brains - two are always needed to complete the flight successfully"
