4 members (66flea, Bucker, JoergK., G508), 92 guests, and 3 robots.
Topics128,269
Posts1,058,404
Members48,485
#588591 11/01/2009 4:31 AM
Y
Y Offline
Hey all-
I have a 49 1/2 ton. stock everything. I have tried about everything and so far nothing works.
On the right rear wheel the when I apply the brake pedal the wheel locks up.
I have tried-
Adjusting shoes first- slight drag, then backed off 4 clicks, the brake stuck again, so 5 clicks, again so 6 clicks.
I have tried bleeding fluid until it ran nice and clean from the wheel cylinder.
I replaced the brake shoe return springs
I have tried adjust the shoes even further out and it still eventually locks up-
the only thing I have not done is to replace the wheel cylinder.
Any ideas?
1949 Chevy 4400 Big Red
1949 Chevy 3600 Bob's Truck
1949 Chevy 3100 The Investment
1949 Chevy 3800 the Won Ton
did you replace the rubber line to the axle?
Y
Y Offline
one of the few things I have not-
Other than waiting on the responses here I plan on a new hose- and cleaning out that cylinder and using a rebuild kit on it.
Yup, replace that PESKY rubber line to the axle, mine cost me a full day of frustration and curse words a sailor wouldnt want to hear when I was trying to get the new sytem (less that line) bled and adjusted....NEW LINE an WHALLA all was good.
Tim
1952 Chevy Shortbed
Photos in Photobucket
Why would a rear brake hose lock up one rear wheel specifically? I would suspect contaminated shoes. There is or has been gear lube or brake fluid on the shoes at one time. Cleaning and sanding won't fix them, just replacement,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I think Scott is right. Check to see if the other side is soaked.
Same problem with my 49 half ton last year. Wheel cylinder? Piston not returning? Contaminated drum or shoes. Try sanding them. Rubber line feeds both sides. On the front I could see that as a potential problem.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
When I re-did my brakes on my '47 1/2 ton, one of the wheel cylinders was almost seized. Turns out that someone had put in cups that were too large for the cylinder(1 and 1/4 inch instead of 1 and 3/16 inch)Maybe something to check.
It's a small world, but I wouldn't want to paint it.
Apprentice
Apprentice
The reason you could get one side bleeding off and the other side not is resistance from wheel cylinder it will prevent flow. Anything in the cylinder not moving at the same rate as the other side, oversized cup, dirty cylinder will cause this.
You cannot measure a man by where he sits in comfort and security, but where he stands in times of adversity and danger.
I had a similar problem with the right rear brake on my '49.
I had rebuilt all the wheel cylinders and they seemed to be working fine.
I inspected my work several times and then one day it locked up worse than usual.
I took it apart and the drum was cracked.
The earlier problem must have been from when the crack was not yet visible when at rest but would expand under braking pressure.
Ray
Y
Y Offline
thanks all- looks like a good saturday project
I had a Honda 750 with a new replacement cup that was too long (as darylbb63 mentions). When the piston retracted, the cup did not pass the relief port. Each squeeze of the brake handle caused the calipers to tighten. By the 3d squeeze the front wheel locked up. Not what you want on a motorcycle! I shaved the cup with a razor blade (I was too poor to buy another) and she worked fine another 60k.
Dave.
What's the last thing a red neck says, "Hey guys watch this."
What's the last thing a redneck hears, "Go ahead Bubba, you can do it."
Build plan: 65 Chevy one ton, 5.9L Cummins HO, NV5600 six speed, 2wd 1972-1987 IFS disk front, frame off restore/mod, custom dump/flat bed, Alcoa rims, Dana 70 3.73:1 duals drum rear, plush interior, Guards red with Marine Corps decals. Donor is retired 2002 Ram 2500, 194K miles.
Y
Y Offline
This truck has all the original brake components- it has just had fluid flushes over the years-
I am planning to rebuild/replace the four cylinders- along with inspecting the pads-
yes the back right shoes had brake fluid on them from a leaky wheel cylinder-
So it is a definate candidate for service
I would say you are on the right track Yelostn78.
Even if the pads look good but have been oil soaked, cleaning them may still result in sticky brakes. Might want to consider replacing them.
