| | | Forums66 Topics128,083 Posts1,055,967 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 76 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 76 | does anyone know how to get the stud out of the window crank handles for a 1946 chevy pickup.i bought new knobs and want to put them on.thansk | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | mmmmm, I probably should stay out of this as its been 20 years since I had a 46. But, if the "stud" is bradded on the back side you will have to grind it off. Does your new handle have a hole through it?? If so you may have to go the nut/bolt route..... I'm sure someone with the REAL answer will come along soon and this post will bump it to the top  | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | Your new knobs should have come with new studs. If so I think you can just cut off the old knobs flush with the crank arm using a cutoff wheel on a dremel . Then you should be able to use a punch and tap it out from the front side to the back. Be sure to support the back side of the crank arm. It's been awhile but I think this is the way I did mine. Good Luck George | | |
