2 members (Bill Hanlon, Otto Skorzeny), 111 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#588464 10/31/2009 11:42 PM
1 Offline
does anyone know how to get the stud out of the window crank handles for a 1946 chevy pickup.i bought new knobs and want to put them on.thansk
mmmmm, I probably should stay out of this as its been 20 years since I had a 46. But, if the "stud" is bradded on the back side you will have to grind it off. Does your new handle have a hole through it?? If so you may have to go the nut/bolt route.....
I'm sure someone with the REAL answer will come along soon and this post will bump it to the top smile
Your new knobs should have come with new studs. If so I think you can just cut off the old knobs flush with the crank arm using a cutoff wheel on a dremel . Then you should be able to use a punch and tap it out from the front side to the back. Be sure to support the back side of the crank arm.
It's been awhile but I think this is the way I did mine.
Good Luck
George
Moderated by  ndkid275, Phak1
