0 members (),
136
Mod | | | Forums66 Topics128,193 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#58767 04/04/2006 6:17 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Still investigating radial tires and two of the tire shops I spoke to say I need tubes because the stock rims do not have a safety lip on them. The tires could 'roll' off. Other shops say it is okay to run them tubeless. | | |
#58768 04/04/2006 6:27 PM | Joined: Nov 2000 Posts: 582 Shop Shark | | Shop Shark Joined: Nov 2000 Posts: 582 | Well, I purchased five rims with the hubcap clips a long time ago through the Parts Wanted forum. Installed Michelin LTX AT radials on them without any problem. The tire shop even went so far as to mark each tire and rim combination as to where they should be mounted on the truck for the best ride and wear. Guess he forgot I was driving a '49 bolt! | | |
#58769 04/04/2006 7:03 PM | Joined: Mar 2005 Posts: 627 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 627 | My original 16" 1955.1 rims had radials on them. It took every bit of strength for 2 husky men to pry a tire off over the rim and that was after the beads were broken totally free.
Mike Barnes 1950 GMC 1-ton pickup
#58770 04/04/2006 7:09 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | somebodies pullin yer chain Bill - the only thing that might prevent tubeless workin on old rims is if they're riveted and the rusty rivets leak, those guys just wanna catch the profit on some old tubes they got kickin around - nothing different about the lips on our truck rims - spend yer money at shops that know their job!
Bill | | |
#58771 04/04/2006 8:53 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I think the safety bead is supposed to keep the bead in place when the tire goes flat. | | |
#58772 04/04/2006 9:01 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Inner tubes are not going to keep the bead in place and there is only a safety bead on one side of the rim.
You can train any kid how to change a tire, but many kids can't be trained to really know anything about anything. | | |
#58773 04/04/2006 9:50 PM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I put tubes in mine, but that was because that was how Grandpa had done it for years, and he was helping me. Of course, I have the Stock Split Rims, so the tire stores didn't want to even have them on the property.  | | |
#58774 04/05/2006 1:14 PM | Joined: Jan 2001 Posts: 1,426 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,426 | I've got 27,500 miles (in 5+ years) on stock rims with 215 85R 16 LT Michelin's. Many people told me it would be safe and I took their advice. This application is on a 3100 1/2 ton.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#58775 04/05/2006 1:23 PM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | I have a 50 Chevy 1/2 working truck with 215-85-16 load range D radials,no tubes,mounted on rivited 5 inch wide late 50's rims.No problems and they hold air fine. | | |
#58776 04/05/2006 5:39 PM | Joined: Jul 2002 Posts: 358 Shop Shark | | Shop Shark Joined: Jul 2002 Posts: 358 | Originally posted by Tony: I have a 50 Chevy 1/2 working truck with 215-85-16 load range D radials,no tubes,mounted on rivited 5 inch wide late 50's rims.No problems and they hold air fine. Ditto. | | |
#58777 04/05/2006 5:53 PM | Joined: Dec 2003 Posts: 299 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2003 Posts: 299 | Bill I have a set of original rims on my 47 ford trailer. I installed bias ply tires on them and I left the tubes off. They hold air perfectly, I think unless your rims are damaged, you should be fine.
Lothar | | |
#58778 04/05/2006 5:54 PM | Joined: Nov 2000 Posts: 1,974 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,974 | I have a 50 3/4 ton with the stock 15" 2-piece rims and I put 235/75-15 radials on them by myself. You have to use tubes and flaps (liners) for them to seal. They run great. This is the second truck I have put radials on. DO IT! :p
Professional Novice
#58779 04/05/2006 6:32 PM | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Sounds like I am going to fore go the tubes! The only other thing I was told by an outsider was the concern for high speed cornering (me, in a 49!!) and the only time I turn tight is to go into a driveway, but it is not fast. | | |
#58780 04/05/2006 10:58 PM | Joined: Apr 2006 Posts: 3 Junior Member | | Junior Member Joined: Apr 2006 Posts: 3 | I have a 1951 Chevy 1/2 ton 3100 running Michelin radials on stock rims. I tried running them tubeless for a while but they kept loosing air. I finally put tubes in and they are fine now. | | |
#58781 04/06/2006 3:32 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | The only problem that I have ever had with putting tubes inside tubeless tires on old rims is when they are first inflated air can become trapped between the tube and the tire. This air will eventually leak out. If not through one of the rivets it will surely come out around the tub’s valve stem as it is not sealed to the wheel. Once this air is out you will have a low tire, but all the air will be inside the tube. Re-inflate to your desired pressure and you will be ok | | |
#58782 04/06/2006 7:25 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | Some Michelin truck tires still require tubes. I ran into the same thing on my 57. As a rule though running tubes make a radial harder to balance,harder to keep balanced,harder riding,and the tubes will make them run hotter.Unless you have a tire or a wheel that leaks and can't be sealed,or unless you run offroad a LOT,I don't recommend 'em. Speed | | |
