Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (Peggy M, 68ironhead, TUTS 59, Bill Hanlon, Hambone), 72 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#58450 03/29/2006 2:41 AM
Junior Member
Junior Member
Here's the deal... I have a 54' chevy 3100 with 235 1bbl rochester. The truck will idle for hours, no problem.. take it on the road.. a block away dies. No fuel getting to the carb. Needles not stuck...
Here's what I've done... Washed the fuel tank... replaced fuel lines with stainless... new fuel pickup... new fuel pump... rebuilt carb.. replaced inline fuel filters with glass bowl..
Still same problem... now before I spend more money on theories of mine I'd like to to get some imput...
could air filter variations have any effect.. oil bath.. chrome.. none..
#58451 03/29/2006 2:57 AM
Make sure the gas cap is vented. Next time you are out and the truck dies, loosen the fuel cap and listen for the tell tale sucking noise. Leave the cap a little loose and see if this fixes the problem.
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#58452 03/29/2006 2:57 AM
check the pushrod for the fuel pump - might be bent or worn enuff to not pump well at higher fuel usage rates above idle - air filter won't affect fuel supply
#58453 03/29/2006 3:27 AM
Junior Member
Junior Member
Does the fuel supply have any relations to the coolant system.... I have a new radiator, new waterpump and new hoses.... I've noticed a lot of pressure building in the system... enough to where I have seen it blow coolant out of the overflow reservoir and even collapse the hoses...
#58454 03/29/2006 3:48 AM
If you're just idling, it will do that.
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#58455 03/29/2006 3:56 AM
hot or cold shouldn't affect fuel supply - make sure your thermostat is functional and you're not overfilling the rad - leave an inch or more down or it'll blow off
#58456 03/31/2006 3:57 PM
FTCorona, Have you figured this one out yet?
Jim
#58457 03/31/2006 8:37 PM
float level set wrong or with a small hole can cause you the same kind of problems.
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
#58458 04/01/2006 5:35 AM
Junior Member
Junior Member
No luck yet.. The gas cap is vented and made no changes on the dying.. as for the mechanical fuel pump, I cheated and got a 6v master electric pump.. I have a constant source of fuel to the filter bowl right before the carb.. thought this fixed it.. took it out.. died two blocks.. same thing.. I re-adjusted the float.. needle.. nothing.. the needle isn't sticking.. time to ditch the rochester??
#58459 04/01/2006 12:35 PM
mayby when your condenser gets hot it shorts out mayby its not fuel
#58460 04/01/2006 1:02 PM
when it dies you say no fuel to carb,,take oil can with gas in and squrit in carb top see if starts,, if no check ing,,if starts remove line at carb and crank over no fuel???If fuel at carb remove air cleaner and open throttle see if acc pump shoots fuel,,if yes you have other problem,,if no remove top of carb see if fuel in bowel,,if no needle sticking if yes look for blockage in jet..doc
#58461 04/13/2006 5:29 PM
Junior Member
Junior Member
Still no luck.. Here's what I've done, I ditched the rochester and installed the 2bbl holley weber carb from langdon's. She fired right up, and idled like a dream. However, like before, I took her out on the road and made it two blocks, and then she started hesitating and once again stalled out.. I shut her off... start the electric fuel pump again, and after about four cranks she fires and idles like a dream... take it another block or two, same thing? I still believe it is lack of fuel but its a entirely new system... has anyone tried to run the fuel line out of the drain hole on the bottom of the tank and ditched the fuel pickup?
evan
#58462 04/13/2006 5:59 PM
I had one that did that. It was a small leak in the fuel line. If you had a mechanical fuel pump, I would suggest getting a tank of gas (the kind you fill the lawn mower up with) and buy 5 feet of gas line and by-pass your truck tank. I am sure you have turned the electric fuel pump on and checked for leaks (it should almost spray gasoline). Keep us informed.
Always get a 2nd opinion, especially if I am the source of the 1st opinion.
#58463 04/13/2006 10:02 PM
Ex Hall Monitor
Ex Hall Monitor
If you can rig a small gas tank, like a small motorcycle tank, under the hood and run a line from it to the electric fuel pump, you can remove the suspect tank from the loop. Fire the truck and if it runs OK you know the problem is in the tank or the lines from the tank. If it continues to stall, the problem is from that point forward. Question, when it stops running does it sputter & buck as it dies or does it just shut off like the key was turned off? If it sputters & acts like it's running out of gas it probably is & you're on the right track. If it just shuts off, it's probably electrical and you are looking for a fuel problem that doesn't exist.
#58464 04/13/2006 10:36 PM
i'd start looking for electrical. all fuel supply is new. check your coil, they'll do what your explaining. they get hot, won't work. cool down will idle fine.
#58465 04/14/2006 2:39 AM
Drive it 'til it dies, get out and see if you have fuel. If the accelerator pumps nothing but air, you have a fuel starvation problem still. Take carb spray with you and see if it will run on it when the truck dies, that will tell you which system that needs attention,
Scott
Scott Ward
1 1950 3100
1 1955.1 Chevy 6500
1 1963 K20 (454)
1 1964 C10 (350)
#58466 04/14/2006 3:37 AM
Does your glass bowl fuel filter show fuel in it when it dies? Wonder if you have something in the tank that keeps getting sucked over the outlet?
40 Chevy 1/2 ton
#58467 04/14/2006 4:09 AM
Mine is doing something very similar. Its a 53 3100 w/216 and carter yf carb. Idles like a dream, bogs down when driven, cant get out of second it stumbles so bad.
Ive replaced fuel pump, plugs, wires, cap, rotor, condenser, blew out the lines looked in the tank-absolutely not a speck of rust, cleaned out the fuel filter, rebuilt carb, Im in the same boat.
It ran fine around town for a few weeks before this then sat in the garage for a week. Now I scream everytime I try to fix it. :mad:
I would be thrilled to see this problem resolved also. I thought I read a post (similar subject) about someone who replaced the valve where the line goes into the tank and that fixed their problem. Any ideas???
I hope someone comes up with something. Im getting really annoyed, I just get to sit in it in the garage and pretend to drive it :rolleyes:
Thanks, Jeff
My 1953 Chevrolet
1947.1 Gallery
#58468 04/14/2006 5:54 PM
It may be the altitude. Not the attitude.
Your truck wants to come to Texas. Trucks like Texas and Texas likes trucks.
I had an MG that always had vapor lock. I carried a bottle of water to cool it down. Did you move the fuel lines?
Just an idea.
Dennis
