7 members (Bill Hanlon, Hanks custodian, gswbbc, cmayna, Otto Skorzeny, oldsteve, Stovebolt48), 139 guests, and 3 robots.
Topics128,042
Posts1,055,520
Members48,424
#582704 10/12/2009 7:35 PM
Riding in the Passing Lane
What is a good shifter to use with my Saginaw 4 speed? I paid big bucks for a Hurst & it seems like a piece of junk. It has no positive feel to it. It wants to go from 1st. to 4th instead of 2nd. I have all the rods adjusted right.
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. #582768 10/13/2009 12:16 AM
Y
Y Offline
Does anybody else make a "4spd" shifter? I've had Mr Gasket on a 3spd. I thought the idea of the shift pattern was designed so that you had to hold it inline for 1st & 2nd while the spring load lined of 3 & 4? I think Hurst does have the good,$ better,$$ & best $$$.
Yakimabowtie #582780 10/13/2009 12:52 AM
If you got the Hurst Indy, I've never seen one that was any good, 3 0r 4 speed. Have you checked with Patricks? They've got a shifter for the Saginaw that's specifically for use in the AD and TF trucks.
BTW, Hurst and Mr.Gasket are the same company, Mr. Gasket bought out Hurst some time ago, mid-'80s, I think.
Bill Burmeister
LONGBOX55 #582790 10/13/2009 1:08 AM
Check with B&M, they make good stuff. Don't know if Lokar makes what you want but worth checking into, maybe,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
LONGBOX55 #582806 10/13/2009 1:50 AM
I'm pretty sure it was B&M that bought them.
Either way, I'm using a Hurst in my '58 with good luck so far. I don't have the part number written down, but if yours mounts to the transmission like this, or if you're interested I'll be glad to get it for you.
Avette4me #582810 10/13/2009 1:58 AM
Used a Hurst up until I went with the T-5 trany, but bought it 20 years ago was really stout. Today's are probably made in Pakistan!
1946 1/2-Ton Chevy
Avette4me #582812 10/13/2009 2:09 AM
Looks like we're both right. From what I could find, B&M bought Hurst from Mr. Gasket.
I might be mistaken, but I thought Lokar only did automatic shifters.
Bill Burmeister
LONGBOX55 #582818 10/13/2009 2:42 AM
I have bought a half a dozen Hurst shifters that were 40 year old NOS on eBay, and of course they still fell like a Hurst. I even think a used 40 year old Hurst is better than what is being built now.
crenwelge #582827 10/13/2009 3:23 AM
Leo Offline
Moderator
Moderator
I've had no problems with Hurst shifters, but mine may be older models.
Leo #582831 10/13/2009 3:29 AM
The quality got pretty sloppy (pun intended) during the Mr. Gasket years. Most of them feel worn out right out of the box. I've driven a few trucks with the Indy Shifter, they were bad enough that I would never suggest them.
Bill Burmeister
Leo #582832 10/13/2009 3:29 AM
I have a Hurst 3 speed shifter on my 65 galaxie and its not that great and looks cheesey as the Mr Gasket versions,when it goes to a 4 speed I have a old Hurst shifter that will be going on. I got the cheesey version off ebay thinking it was a good one but it was cheap and better then on the column.
Jeff Ogden #582933 10/13/2009 2:32 PM
I learned a couple things years ago with aftermarket shifters. I always would use the metal bushings in the shift arms, both shifter end and transmission end. The nylon bushings are soft and add to the slop factor. I also always used a 1/4" (guess) drill bit to adjust the shifter arms. Put the transmission in neutral have the arms of the transmission and shifter in neutral, then slide the bit in to lock shifter in place. Then adjust each rod to the correct length. Then if your shifter has the 3/8 bolts with the lock nuts to limit the travel make sure you adjust them to make sure you are engaging each gear all the way. The last thing is to make sure the shifter assembly stays clean and lubed, it makes a big difference.
Don
don stocker #583038 10/13/2009 8:56 PM
Thanks for the replies. It is the Indy shifter. It looks like the one in Avette's photo but doesn't have the stops. I think I will e-mail or call Hurst & see what they say. George
That isn't good. I'd ask them about that when you call.
Avette4me #583274 10/14/2009 4:37 PM
Its possible that the end plates are threaded for the stops. You can get some 3/8 bolts and put a nut on them and go ahead and adjust things up.
LONGBOX55 #583642 10/15/2009 11:43 PM
I have nobody to blame but myself. I should have asked first before I bought it. I could have put in a T-5 for about the same money.
Wrenchbender Ret. #584461 10/18/2009 10:52 PM
Patrick's is made by Hurst, I am fairly certain. I didn't hear that people were having problems with them feeling sloppy though. I am not sure if his is built, or speced differently though.
pplummer #589944 11/05/2009 2:52 PM
Update. I called Hurst & they said that is the cheaper line & just the way it is. I called Jed's & after a long lecture on how to drive a manual trans. (I've been driving them for 60 years, everything from Semi's to muscle cars to VW's) He said to send it bsck. I sent it back to them & am going to put a T-5 in it.
