1 members (baldeagle),
33
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | What is a good shifter to use with my Saginaw 4 speed? I paid big bucks for a Hurst & it seems like a piece of junk. It has no positive feel to it. It wants to go from 1st. to 4th instead of 2nd. I have all the rods adjusted right.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Does anybody else make a "4spd" shifter? I've had Mr Gasket on a 3spd. I thought the idea of the shift pattern was designed so that you had to hold it inline for 1st & 2nd while the spring load lined of 3 & 4? I think Hurst does have the good,$ better,$$ & best $$$. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you got the Hurst Indy, I've never seen one that was any good, 3 0r 4 speed. Have you checked with Patricks? They've got a shifter for the Saginaw that's specifically for use in the AD and TF trucks. BTW, Hurst and Mr.Gasket are the same company, Mr. Gasket bought out Hurst some time ago, mid-'80s, I think.
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Check with B&M, they make good stuff. Don't know if Lokar makes what you want but worth checking into, maybe, Scott | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | Mr. Gasket bought out Hurst some time ago, mid-'80s, I think. I'm pretty sure it was B&M that bought them. Either way, I'm using a Hurst in my '58 with good luck so far. I don't have the part number written down, but if yours mounts to the transmission like this, or if you're interested I'll be glad to get it for you.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Used a Hurst up until I went with the T-5 trany, but bought it 20 years ago was really stout. Today's are probably made in Pakistan! | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Mr. Gasket bought out Hurst some time ago, mid-'80s, I think. I'm pretty sure it was B&M that bought them. Looks like we're both right. From what I could find, B&M bought Hurst from Mr. Gasket. I might be mistaken, but I thought Lokar only did automatic shifters.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I have bought a half a dozen Hurst shifters that were 40 year old NOS on eBay, and of course they still fell like a Hurst. I even think a used 40 year old Hurst is better than what is being built now. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | I've had no problems with Hurst shifters, but mine may be older models. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The quality got pretty sloppy (pun intended) during the Mr. Gasket years. Most of them feel worn out right out of the box. I've driven a few trucks with the Indy Shifter, they were bad enough that I would never suggest them.
Bill Burmeister | | | | | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | I have a Hurst 3 speed shifter on my 65 galaxie and its not that great and looks cheesey as the Mr Gasket versions,when it goes to a 4 speed I have a old Hurst shifter that will be going on. I got the cheesey version off ebay thinking it was a good one but it was cheap and better then on the column. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | I learned a couple things years ago with aftermarket shifters. I always would use the metal bushings in the shift arms, both shifter end and transmission end. The nylon bushings are soft and add to the slop factor. I also always used a 1/4" (guess) drill bit to adjust the shifter arms. Put the transmission in neutral have the arms of the transmission and shifter in neutral, then slide the bit in to lock shifter in place. Then adjust each rod to the correct length. Then if your shifter has the 3/8 bolts with the lock nuts to limit the travel make sure you adjust them to make sure you are engaging each gear all the way. The last thing is to make sure the shifter assembly stays clean and lubed, it makes a big difference. Don | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Thanks for the replies. It is the Indy shifter. It looks like the one in Avette's photo but doesn't have the stops. I think I will e-mail or call Hurst & see what they say. George They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Feb 2006 Posts: 549 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 549 | but doesn't have the stops. That isn't good. I'd ask them about that when you call. | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Its possible that the end plates are threaded for the stops. You can get some 3/8 bolts and put a nut on them and go ahead and adjust things up. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I have nobody to blame but myself. I should have asked first before I bought it. I could have put in a T-5 for about the same money. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2007 Posts: 321 Shop Shark | | Shop Shark Joined: May 2007 Posts: 321 | Patrick's is made by Hurst, I am fairly certain. I didn't hear that people were having problems with them feeling sloppy though. I am not sure if his is built, or speced differently though. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Update. I called Hurst & they said that is the cheaper line & just the way it is. I called Jed's & after a long lecture on how to drive a manual trans. (I've been driving them for 60 years, everything from Semi's to muscle cars to VW's) He said to send it bsck. I sent it back to them & am going to put a T-5 in it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
