Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
7 members (Peggy M, Hambone, 68ironhead, 2-Ton, TUTS 59, DaveV, msmall), 54 guests, and 2 robots.
Topics128,009
Posts1,055,296
Members48,419
#57799 03/16/2006 9:59 AM
A friend of mine did me a "favor" today and removed the head from my 216 to check the head gasket. I noticed he tossed the push rods in the valve cover. Usually when I do this I poke them into a cardboard box and label them so I can put them back with thier respective valve. Guess I wont be doing that this time. My question is...will this really matter when I put this thing back together? Thanks
Chris Simmonds
1942 Chevy 3/4 ton
#57800 03/16/2006 10:16 AM
It's usually good to keep the pushrods matched to the components at each end of 'em,mainly because they wear a pattern to each other,and swapping them around could cause accelerated wear while they develop a new pattern. I suspect in this case the only problem is likely to be that you'll have to adjust your valves a couple more times to compensate for the extra wear. I don't think I'd worry too much about it.
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
#57801 03/16/2006 8:44 PM
When you get it back together and running watch the pushrods and see if they're turning. If they are rotating slowly they are happy and perfectly concentric. Ones that don't want to turn will develop a "rut". Swap around the stiff ones and polish the ends of a few if you have to to get them all moving.
You Tube
#57802 03/17/2006 12:54 AM
Maybe he's going to hit you up for a new set of rods and rockers,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
