| | | Forums66 Topics128,006 Posts1,055,268 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#57799 03/16/2006 9:59 AM | Joined: Mar 2002 Posts: 126 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2002 Posts: 126 | A friend of mine did me a "favor" today and removed the head from my 216 to check the head gasket. I noticed he tossed the push rods in the valve cover. Usually when I do this I poke them into a cardboard box and label them so I can put them back with thier respective valve. Guess I wont be doing that this time. My question is...will this really matter when I put this thing back together? Thanks
Chris Simmonds 1942 Chevy 3/4 ton | | |
#57800 03/16/2006 10:16 AM | Joined: Apr 2005 Posts: 926 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 926 | It's usually good to keep the pushrods matched to the components at each end of 'em,mainly because they wear a pattern to each other,and swapping them around could cause accelerated wear while they develop a new pattern. I suspect in this case the only problem is likely to be that you'll have to adjust your valves a couple more times to compensate for the extra wear. I don't think I'd worry too much about it. Speed | | |
#57801 03/16/2006 8:44 PM | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | When you get it back together and running watch the pushrods and see if they're turning. If they are rotating slowly they are happy and perfectly concentric. Ones that don't want to turn will develop a "rut". Swap around the stiff ones and polish the ends of a few if you have to to get them all moving.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
#57802 03/17/2006 12:54 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Maybe he's going to hit you up for a new set of rods and rockers, Scott | | |
