1 members (1 invisible),
89
Mod | | | Forums66 Topics128,034 Posts1,055,546 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Gang,
I've been looking all over my little town for the exhaust studs to fit my 53 216 engine. Can't seem to find them anywhere. NAPA, Lowes, O'reileys look at me like I have two heads, we don't have an Ace hardware. Does anybody know where I can get them.
Charlie
1953 5 Window 1994 Harley, Heritage Softail Classic 2006 Chevy Colarado I didn't say it was your fault, I said I was blaming you.
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | They should have head them at either parts store. Thise studs are just 3/8" NC thread studs, nothing really special.
Bill Burmeister | | | | | Joined: Jan 2009 Posts: 1,644 Shop Shark | | Shop Shark Joined: Jan 2009 Posts: 1,644 | Most of the FLAPS here have nut and bolt drawers so You can find what You need Your self in one section they will have studs for exhaust they are black and come in inch and metric so just match up what You need ,like Longbox55 said nothing special .
Pete | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ... just make sure you put some anti-sieze on them and make sure they are not the cheap ones. They will twist off the first time you ever take the exhaust loose. | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | Just a tip..get the BRASS exhaust stud nuts...it makes life SO MUCH EASIER a yr or 10 down the road. Tim | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'll second that Tim. I just pulled the exhaust pipe off my manifold last week and thanks to the guy that last installed an exhaust system, it had brass tall nuts on it. I was anticipating a battle and all I got was a little squeak as they spun right off, making me one happy camper. Ya see, I'm camped out under that truck most of the time the last three years. Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2005 Posts: 487 'Bolter | | 'Bolter Joined: May 2005 Posts: 487 | O'Reilly and Autozone both carry Motormite (Help!) products. If you can't break through their mental fog any other way, ask for Motormite #03112. It's 3 2-1/2" studs (3/8-16), 3 brass nuts and 3 lockwashers. That's one more than you need, but it will get you out of the store with your parts. If you're using the donut gaskets, you might need #03113, which is the same kit with 3-1/4" studs.
regards, Leon | | | | | Joined: Apr 2009 Posts: 431 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 431 | with brass, does the anti-geeze become a moot point? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Actually it does in a way. The steel thread is not going to get distorted or torn up by the brass so the brass really has nothing to tear up its thread as long as the thread aren't all rusted up. Steel on steel or similar metals in general, will gaule both pieces this is where the anti-seze is especially needed. But it never hurts to use anti-seze on any threaded fastener. The brass nuts just spun right off on my exhaust after being on for at least a couple of decades, but I alway wire brush real good, any exposed thread before I try removing any fastener. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | I love the anti-seize. I even on my hubs where the wheel is doing to mate. It won't rust. I hadn't heard about the brass nuts. Are they specially exhaust nuts? Do they have a grade indicated? A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | not sure about the grade indication but they are not "special" exhaust nuts. Just be sure to ask for the "tall" ones. | | | | | Joined: Mar 2009 Posts: 134 Shop Shark | | Shop Shark Joined: Mar 2009 Posts: 134 | Oreilys to the rescue. They had the kit installed them all is well for now. Thanks to all who responded.
Charlie
