3 members (49 panel, UtahYork, Nick in Manitou), 65 guests, and 2 robots.
Topics128,030
Posts1,055,428
Members48,422
#575612 09/18/2009 11:38 PM
Gang,
I've been looking all over my little town for the exhaust studs to fit my 53 216 engine. Can't seem to find them anywhere. NAPA, Lowes, O'reileys look at me like I have two heads, we don't have an Ace hardware. Does anybody know where I can get them.
Charlie
1953 5 Window
1994 Harley, Heritage Softail Classic
2006 Chevy Colarado
I didn't say it was your fault, I said I was blaming you.
Charley #575620 09/18/2009 11:55 PM
They should have head them at either parts store. Thise studs are just 3/8" NC thread studs, nothing really special.
Bill Burmeister
LONGBOX55 #575635 09/19/2009 12:59 AM
Most of the FLAPS here have nut and bolt drawers so You can find what You need Your self in one section they will have studs for exhaust they are black and come in inch and metric so just match up what You need ,like Longbox55 said nothing special .
Pete
Pete52 #575660 09/19/2009 2:18 AM
... just make sure you put some anti-sieze on them and make sure they are not the cheap ones. They will twist off the first time you ever take the exhaust loose.
Achipmunk #575750 09/19/2009 8:51 AM
Just a tip..get the BRASS exhaust stud nuts...it makes life SO MUCH EASIER a yr or 10 down the road.
Tim
1952 Chevy Shortbed
Photos in Photobucket
SW_Radial #575760 09/19/2009 12:27 PM
I'll second that Tim. I just pulled the exhaust pipe off my manifold last week and thanks to the guy that last installed an exhaust system, it had brass tall nuts on it. I was anticipating a battle and all I got was a little squeak as they spun right off, making me one happy camper. Ya see, I'm camped out under that truck most of the time the last three years.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
O'Reilly and Autozone both carry Motormite (Help!) products.
If you can't break through their mental fog any other way, ask for Motormite #03112. It's 3 2-1/2" studs (3/8-16), 3 brass nuts and 3 lockwashers. That's one more than you need, but it will get you out of the store with your parts. If you're using the donut gaskets, you might need #03113, which is the same kit with 3-1/4" studs.
regards,
Leon
Leon #575825 09/19/2009 4:07 PM
with brass, does the anti-geeze become a moot point?
rednate #575827 09/19/2009 4:20 PM
Actually it does in a way. The steel thread is not going to get distorted or torn up by the brass so the brass really has nothing to tear up its thread as long as the thread aren't all rusted up. Steel on steel or similar metals in general, will gaule both pieces this is where the anti-seze is especially needed. But it never hurts to use anti-seze on any threaded fastener. The brass nuts just spun right off on my exhaust after being on for at least a couple of decades, but I alway wire brush real good, any exposed thread before I try removing any fastener.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Big Bolt Forum Co-moderator
I love the anti-seize. I even on my hubs where the wheel is doing to mate. It won't rust. I hadn't heard about the brass nuts. Are they specially exhaust nuts? Do they have a grade indicated?
1948 Chevy 2-Ton
Super55 #576139 09/20/2009 4:27 PM
not sure about the grade indication but they are not "special" exhaust nuts. Just be sure to ask for the "tall" ones.
Achipmunk #576163 09/20/2009 5:45 PM
Oreilys to the rescue. They had the kit installed them all is well for now. Thanks to all who responded.
Charlie
1953 5 Window
2006 Chevy Colarado
