3 members (Nick in Manitou, CuzzFuzz, Tronman), 115 guests, and 2 robots.
Topics128,080
Posts1,056,314
Members48,442
#56885 02/21/2006 9:39 PM
Stovebolt Brothers and Sisters,
Redoing all of the brake system in my 58 (The Beast, Miss February 2006 in the Stovebolt Calendar) and bought pre-bent lines. As usual, one piece is approximately 3 1/2" short, so I need to bridge the gap. Shortest line available is 8", so I tried to bend a few curves to make it fit. Well, it does not work.
Went to the local NAPA, where I found that a flaring tool was financially out of the question. The enterprising young man behind the counter suggested to shorten the 8" piece and join the two ends back together with a 3/16" union.
Now, Ladies and Gentlemen, while the cheapskate part of me thinks this may be a good idea, my rational part thinks that this may not be so kosher (or safe!!). Have any of you used unions in your braking system, and lived to tell about it?
:confused:
Thanks for your opinions and comments,
Richard
58 3104
#56886 02/21/2006 9:48 PM
I recently redid my brakes in the '46 with prebent lines, and the master cylinder to junction block like was wrong. Instead of attempting to fix it, I sent the line back with the original, and they hooked me up with the right line, free of charge.
Try to get the right line before you start jury-rigging stuff. Brakes are something you don't want to rig up unless you absolutely have to.
#56887 02/21/2006 10:55 PM
Riding in the Passing Lane
It is unsafe & illegal to use compression unions in brake tubes. A double flare tool set should not be all that expensive or have a machine shop flare it for you. You can use inverted flare unions with the tube double flared.
1972 Chevy c10 Cheyenne Super
#56888 02/22/2006 1:04 AM
Instead of buying a very good flaring tool and only needing it two or three times in my life
I made up all my brake lines and took them to a brake shop where they ''did the ends up right nice'' and it took about 32 seconds per end.
They charged me $5.00 each
money well spent. grin
Jim & Caroline
#56889 02/22/2006 1:08 AM
I did it but have the right tool, I like the idea of going to a brake shop to have them do the flair for you. sounds like the cheapest and easiest way out
#56890 02/22/2006 2:58 AM
$5 a piece? holy [censored]! that's retarded. Go borrow one from autozone- it even has instructions, it's easy. I liked using it so much i kept it, and let autozone have the deposit! ha! Screw the brake shop.
#56891 02/23/2006 10:58 AM
Maybe we should all have oldcarandtrucknut do our brake lines and screw the brake shop. I'm with jim-if I'm not gonna use a tool a lot,I don't see the point in buying it. Besides,whats wrong with having a PROFESSIONAL brake mechanic do your lines,while YOU work on getting something ELSE done?
Speed
1954 GMC 350
1957 GMC 1/2 ton
1962 Chevy C-30
'98 Harley FLSTC
'66 Pontiac Catalina
'76 Chevy 1 ton Duallie
'84 Bronco II
'78 Dodge W-200
'81 Toyota 4X4 truck
