0 members (),
109
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2009 Posts: 33 Apprentice | | Apprentice Joined: Jul 2009 Posts: 33 | I have the original 235 motor in my 47 Chevy 2 ton truck, but someone had taken the plugs out somewhere down the line while it set (figure 15 years+ with no plugs) What should I expect, can the motor be salvaged, being the original I'd hate to lose it this late in it's life, but would I be better off just getting a full oil pressure 235 out of a later model truck, or would the original be most desireable, just looking for a direction to travel in. Kevin
If it's old and rusted out.... Well it's probably mine. [http://www.stovebolt.com/gallery/weimer_kevin_1947.html]1947 Chevrolet Loadmaster 2 Ton[/url] 1978 Dodge W200/M880 2002 Dodge Ram 2500 Cummins Diesel Photobucket Pix | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | In my opinion, originality is not that big an issue with the big old trucks, they're just not that special to matter. For the price of just a gasket set you could probably upgrade to a newer 235 or even a 261. Just my 2 cents though, Scott | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Save a lot of time and money by finding an engine that runs, and replace the engine. | | | | | Joined: Feb 2004 Posts: 29,774 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,774 | If you decide not to try to salvage it, let me know. I'm accumulating quite a collection of babbit-pounders! Jerry
| | | | | Joined: Jul 2007 Posts: 461 Shop Shark | | Shop Shark Joined: Jul 2007 Posts: 461 | More than likely you can save it, unless the block is broken. I would keep it original if it were mine. Or as close to original as I could keep it.
Harvester | | |
