1 members (homer52),
66
Mod | | | Forums66 Topics128,072 Posts1,055,906 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | I'm getting ready to prime some parts for my truck. I don't have a spray set-up or the money for one. Does anyone have a recommendation for a good rattle can primer that doesn't cost an arm & leg? This is for re-rusting protection, so it doesn't have to be a specific color, or a great finish. The parts will be de-rusted using electrolysis, then phosphoric acid. I've heard etching primers work well, but could have problems on surfaces previously treated with phosphoric acid.
Bryan 1954 3104 235 "AD" L-6 3-on-the tree
| | | | | Joined: Dec 2008 Posts: 59 'Bolter | | 'Bolter Joined: Dec 2008 Posts: 59 | Rust-oleum Auto Primer has always done a good job for me on parts.
"One thing about trains, it doesn't matter where the're going, what matters is, deciding to get on." - Polar Express
| | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | I've had good luck with http://www.vansicklepaint.com/index.html products. they make tractor enamels and are located in Nebraska I think. Big R stores carry it.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | How long will the parts be in primer before putting on a top coat?
Where will the parts be stored before putting on the top coat?
| | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | I'm going to be primering the gas tank and filler neck. It could possibly be YEARS before it's ever painted. The tank is behind the seat though and shouldn't see any weather/UV. The filler neck could probably go w/o any primer at all as it looks like it's galvinized or something similiar. I am just trying to get the truck running reliably at this point. This primer is for function ONLY, not for show.
Remember Rattle Can Primer ONLY
Keep the suggestions coming!!
OH I should mention that I ordered a rubber strap & bumper kit from Jim Carter. So I shouldn't have to worry about the straps rubbing through the primer
| | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | more important than weather its UV protected make sure its a sealer/primer if your planing on storing it for awhile, filler primers can soak up dampness and rust it out as if there was no paint on it at all
1937 1/2 ton
| | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | OK... I primed the gas tank. it did NOT go well. The primer started flaking off in sheets! I've never had this happen on anything I've painted before. the tank had been etched w/ phosphoric acid. then wiped dry, and prepped with acetone. I let it sit for a while to make sure it was dry. then primed w/ no-name NAPA primer ($3.19 per can). It was fairly humid that day...would that have done it? Was it the cheap primer? How can I avoid this in the future? HELP!!
| | | | | Joined: Jun 2009 Posts: 235 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 235 | I hope someone responds to you, I'm kind of curious to know what could have caused that too.
'53 Chevy 3604 Five Window Cab ('56 235)
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not sure what made the primer fail. Could have been the humidity, but I'm more inclined to think either a dud can of primer or poaaibly some sort of contamination on the surface. May have nede a second wipedown before spraying. I can suggest that you try a self etching type primer. Dupli-Color makes a good one, kind of an olive green color. I have also used Dupli-Color and Rustoleum sandable primers with good success.
Bill Burmeister | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Yeah... I'm thinking that I will not be buying cheapo primer again. it's hard to swallow $8/can for a good self etching primer though. Thanks Guys
| | | | | Joined: Aug 2008 Posts: 403 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 403 | It is very possiable you did not wipe the tank down good enough. I use wash thinner and haven't had any problems. The wash thinner evaporates really quickly and leaves a nice clean surface to work with. I also just thought of something if you are going to leave it for a long time why not use some mali box silver on it to keep it from rusting. You can buy this in Rust-oleum paint. 62 Blue Don
62Blue 62Chevy in progress You've never been lost until you've been lost at Mach3" Paul F Crichmore (Test Pilot)
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If you want to save a few $$, Wal-Mart does carry the Dupli-Color Self Etch and Primer/Filler in their automotive departments. IIRC, the last time I picked some up, it was around $6 a can.
Bill Burmeister | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | Hey, a good ole steak isn't cheap and a cheap ole steak isn't good. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... and Advance Auto sales it for $5.98 a can unless its went up on price. I use both the rustoleum and the greenish self etch.
For the what its worth dept. we have a shop here in town that has/does TOTAL restorations for years on nothing but mopar. I deliver the self etch to them all the time. The owner tells me its good stuff especially for the small touch up jobs or small objects. | | | | | Joined: May 2009 Posts: 181 'Bolter | | 'Bolter Joined: May 2009 Posts: 181 | Thanks guys. I've borrowed a sandblaster from my father in law, I'm going to sand blast, hit it really good with paint prep wash, and the use a good self etch on it. if that won't do it, I don't know what will.
| | | | | Joined: Jul 2006 Posts: 190 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Jul 2006 Posts: 190 | You didn't hold the can and spray to too far away from the tank? You want a light coat, but wet coat, then wait a few minutes for it to tack up, then a good even wet coat. The primer could of dried enough before it actually got a chance to adhere to the metal. | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | you could always blast it first the por15 the tank after metal ready prep then the tank is done..
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I painted my tank with some appliance epoxy a few years back. It was a metal tone kind of a silver with a bronze tint. It was outside for most of the 2 years behind the seat of the truck. It still looks great. I am not sure why they call it epoxy when it is one part rattle can paint but no sign of rust or peeling. I did use Duplicolor primer sealer first. | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | being in missouri I can relate to the hunidity thing. I have had prepped surfaces flake off primer in sheets due to humidity. the no name NAPA stuff needs to be constantly shaken to keep it mixed. maybe it settled on you in the can too.
56 stepside 3/4 ton longbed
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | being in missouri I can relate to the hunidity thing. YEPPPPPPPPPPPP & the humidity normally at least matches the temp. And if you don't like St Louis weather, just wait around 10 minutes or so & it'll change...Joe | | | | | Joined: Sep 2002 Posts: 159 Shop Shark | | Shop Shark Joined: Sep 2002 Posts: 159 | you got it, nothing like working on your project and being totally soaked to the skin when you are done
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | you got it, nothing like working on your project and being totally soaked to the skin when you are done That's why I have a 48" fan in my garage. Even on the worse days, hot humid moving air is always better then plain old hot humid none moving air any day....Joe | | |
