Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
5 members (tclederman, rfs56trk, Woogeroo, Peggy M, 1 invisible), 48 guests, and 6 robots.
Topics128,010
Posts1,055,299
Members48,419
#555641 07/14/2009 9:57 PM
Apprentice
Apprentice
Hey verybody-
I have recently been given a nice running 67 chevy truck. Its two wheel drive and I have a 4x4 drivetrain from a 72 truck. I want to know if the frames from 67 to 72 are the same? Any thoughts? Crossmembers? Swapping to leafs up front? Calipers?
Nick
N. Phillips #555700 07/15/2009 12:37 AM
Yes, the frames are the same. How much of the '72 do you have?
Bill Burmeister
LONGBOX55 #555721 07/15/2009 2:04 AM
I doubt they're the same. Coil springs for the 2wd and leaf for the 4x4's. The 60-66 was even shaped quite differently. A body swap would be the easy way to convert,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
I agree, body swap would be easier. That was more what i meant by the frames being the same. The '67-'72 is a different animal than the '60-'66 as far as 4x4 goes. They have more in common with the '73-'87 in how the front is setup. You would be looking at swapping the T-case crossmember, spring mounts, steering box, and axles.
Bill Burmeister
LONGBOX55 #556120 07/16/2009 4:48 PM
N. Phillips is talking about the same style pickup from 67-72. Just the same, a friend of mine just did a body/engine swap.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
Yes your cool '67 cab with the small window will bolt right on the '72 frame. I have done that exact same swap, 26 years ago.
1953 Chevrolet 3600
Fried Green T'mater (Vern)
Caution: Political Statement
