| | | Forums66 Topics128,036 Posts1,055,450 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 38 Apprentice | | Apprentice Joined: Apr 2006 Posts: 38 | Hey verybody-
I have recently been given a nice running 67 chevy truck. Its two wheel drive and I have a 4x4 drivetrain from a 72 truck. I want to know if the frames from 67 to 72 are the same? Any thoughts? Crossmembers? Swapping to leafs up front? Calipers?
Nick | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, the frames are the same. How much of the '72 do you have?
Bill Burmeister | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | I doubt they're the same. Coil springs for the 2wd and leaf for the 4x4's. The 60-66 was even shaped quite differently. A body swap would be the easy way to convert, Scott | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I agree, body swap would be easier. That was more what i meant by the frames being the same. The '67-'72 is a different animal than the '60-'66 as far as 4x4 goes. They have more in common with the '73-'87 in how the front is setup. You would be looking at swapping the T-case crossmember, spring mounts, steering box, and axles.
Bill Burmeister | | | | | Joined: Jul 2005 Posts: 581 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 581 | N. Phillips is talking about the same style pickup from 67-72. Just the same, a friend of mine just did a body/engine swap. | | | | | Joined: Jun 2009 Posts: 2,201 Shop Shark | | Shop Shark Joined: Jun 2009 Posts: 2,201 | Yes your cool '67 cab with the small window will bolt right on the '72 frame. I have done that exact same swap, 26 years ago. | | |
