1 members (stlcardinalsguy),
71
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,430 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2009 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 38 | I just purchased a maroon knob for the hood cowl lever. The knob slips onto the steel lever but what do you recommend to use to keep it attached? I was thinking a super glue or does this knob snap into the lever. This cowl is a center hood type just outside the windshield. | | | | | Joined: Jul 2003 Posts: 586 Shop Shark | | Shop Shark Joined: Jul 2003 Posts: 586 | I would use one of the two part epoxy glues. Cecil....... | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | The end that the knob goes on has a sort of serrated edges on it and when the knob is tapped on the end of the arm it will stay there. If for some reason it is a little loose then a dab of glue should do it. I just did this last week. My old one was tough to get off but after I cleaned and painted the arm up I just tapped the new knob on and it stuck nicely. | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | When I redid the dash in the COE I used a little bit of JB weld. It was a little loose, but never again.  | | |
