7 members (John Dlugos, Bill Hanlon, klhansen, Gray_Ghost, Otto Skorzeny, Gdads51, 1 invisible),
178
Mod | | | Forums66 Topics128,101 Posts1,056,179 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#54460 01/04/2006 6:09 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Does anyone know what 15" tire size will achieve a diameter of 30 - 32" ? Thanks. | | |
#54461 01/04/2006 6:50 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 700R15LT did it for me
Bill | | |
#54462 01/04/2006 6:57 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | | | |
#54463 01/04/2006 7:12 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I'd hafta check, but around 31 if I recall right - noticeably taller than the car size that was on before, and slightly more than original cuz they're 10 plys - I'll measure again tomorrow
Bill | | |
#54464 01/04/2006 8:33 PM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | well it's actually 30" for the 700's when on the truck, which i think is just about what the original 6.70's would be
Bill | | |
#54465 01/04/2006 10:38 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | 7.00-15 is 29". 7" sidewall (times 2) + 15" wheel. To get in the 30" range you end up with tires that are very wide, like the 31x10.50R15 LT. This is 30.4" tire with a 10.9" width.
I went to 16" rims and a 7.50R16 which is a 31" tire. Find a locally owned tire shop that does truck tires, they might be able to help in your selection.
Fred 52 3600 69 C-10
#54466 01/05/2006 12:15 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | | | |
#54467 01/05/2006 11:13 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | So... If I go to a 16" wheel, I can get 31" and have a more narrow footprint? I'm also assuming this might make it easier to steer? What about highway driveability? Thanks for the help. Currently looking at 255 70R-15 (29.1" dia. & 10.3" wide) for the rear and 235 75R-15(28.9" dia & 9.3" wide) for the front. I can still change to 16 wheels - its not too late...yet. | | |
#54468 01/06/2006 5:21 AM | Joined: Dec 2002 Posts: 571 Shop Shark | | Shop Shark Joined: Dec 2002 Posts: 571 | | | |
#54469 01/06/2006 6:16 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | I have 15" wheels on my 3/4 ton. I am currently sporting a set of Cooper 235/75R15 tires that are almost 29" across (Seems like they're 28.87 or something).
Modern radial tires come in several different aspect ratios (ie the "75" part) If you were to go with a 255/80R15, you'd end up with a 31" diameter tire. The only thing is, you're looking at 10 inches wide. In comparison, the 235/75R15's that I'm running on mine are 9.25" wide.
16" wheels are another story. You can get 235/80R16's that will be 9.25" with a diameter of 30.8".
I hope this helpes. | | |
#54470 01/06/2006 6:00 PM | Joined: Dec 2005 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2005 Posts: 47 | i'm running 275/60/R15's on the back of my 66 stepside which is 28 in overall diameter and 8.9 inches wide.
1966 Chevrolet C-10 1971 Chevrolet Camaro RS 1989 Pontiac Bonneville MY GARAGE...www.dragcitygarage.com
#54471 01/07/2006 8:19 AM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | Thanks for your input all. I decided on 16" wheels, tire size P235/75R16. 29.85 diameter, 9.25 section width. | | |
#54472 01/07/2006 5:58 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | I settled on P285-70R15 with a diameter of 30.3" to maintain my original 4:10 gearing. This tire is same as a new original 700x15 that I have. | | |
#54473 01/07/2006 8:49 PM | Joined: May 2004 Posts: 920 'Bolter | | 'Bolter Joined: May 2004 Posts: 920 | I'm currently riding on 7.00 X 15 tube type on split rim wheels. According to owners manual, the original on mine were 7.10 x 15. New radials will be just slightly taller than that. In the next couple of weeks I will be installing the new 16 inch wheels with the radials. I'll come back with an update once I've driven on them a while. | | |
