0 members (), 347 guests, and 1 robot.
Topics128,101
Posts1,056,180
Members48,436
#54460 01/04/2006 6:09 AM
Does anyone know what 15" tire size will achieve a diameter of 30 - 32" ? Thanks.
1962 Fleetside 4spd 235 w/O.D. posi 3:90
1990 Subaru Legacy Wagon AWD 2.2 5sp
2013 Ram Tradesman C/V
My Webshot Photos]
#54461 01/04/2006 6:50 AM
700R15LT did it for me
#54462 01/04/2006 6:57 AM
So what's the diameter?
My Webshot Photos]
#54463 01/04/2006 7:12 AM
I'd hafta check, but around 31 if I recall right - noticeably taller than the car size that was on before, and slightly more than original cuz they're 10 plys - I'll measure again tomorrow
#54464 01/04/2006 8:33 PM
well it's actually 30" for the 700's when on the truck, which i think is just about what the original 6.70's would be
#54465 01/04/2006 10:38 PM
7.00-15 is 29". 7" sidewall (times 2) + 15" wheel. To get in the 30" range you end up with tires that are very wide, like the 31x10.50R15 LT. This is 30.4" tire with a 10.9" width.
I went to 16" rims and a 7.50R16 which is a 31" tire. Find a locally owned tire shop that does truck tires, they might be able to help in your selection.
Fred
52 3600
69 C-10
#54466 01/05/2006 12:15 PM
#54467 01/05/2006 11:13 PM
So... If I go to a 16" wheel, I can get 31" and have a more narrow footprint? I'm also assuming this might make it easier to steer? What about highway driveability? Thanks for the help. Currently looking at 255 70R-15 (29.1" dia. & 10.3" wide) for the rear and 235 75R-15(28.9" dia & 9.3" wide) for the front. I can still change to 16 wheels - its not too late...yet.
My Webshot Photos]
#54468 01/06/2006 5:21 AM
This may help. Tire size calculator wink
#54469 01/06/2006 6:16 AM
I have 15" wheels on my 3/4 ton. I am currently sporting a set of Cooper 235/75R15 tires that are almost 29" across (Seems like they're 28.87 or something).
Modern radial tires come in several different aspect ratios (ie the "75" part) If you were to go with a 255/80R15, you'd end up with a 31" diameter tire. The only thing is, you're looking at 10 inches wide. In comparison, the 235/75R15's that I'm running on mine are 9.25" wide.
16" wheels are another story. You can get 235/80R16's that will be 9.25" with a diameter of 30.8".
I hope this helpes.
#54470 01/06/2006 6:00 PM
i'm running 275/60/R15's on the back of my 66 stepside which is 28 in overall diameter and 8.9 inches wide.
1966 Chevrolet C-10
1971 Chevrolet Camaro RS
1989 Pontiac Bonneville
MY GARAGE...www.dragcitygarage.com
#54471 01/07/2006 8:19 AM
Thanks for your input all. I decided on 16" wheels, tire size P235/75R16. 29.85 diameter, 9.25 section width.
My Webshot Photos]
#54472 01/07/2006 5:58 PM
I settled on P285-70R15 with a diameter of 30.3" to maintain my original 4:10 gearing. This tire is same as a new original 700x15 that I have.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
#54473 01/07/2006 8:49 PM
I'm currently riding on 7.00 X 15 tube type on split rim wheels. According to owners manual, the original on mine were 7.10 x 15. New radials will be just slightly taller than that. In the next couple of weeks I will be installing the new 16 inch wheels with the radials. I'll come back with an update once I've driven on them a while.
My Webshot Photos]
