8 members (Brian Moore, Eileen, cmayna, 1955 1 Series, Otto Skorzeny, Hotrod Lincoln, 55shaker, ronsway),
105
Mod | | | Forums66 Topics128,079 Posts1,056,300 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | Looking for information on installing a 350 motor and tranny in my 53 3/4 ton. gona leave the exsisting front end, i have a 235 in it now, looking for motor mount and transmission advice. thanks | | | | | Joined: Jul 2006 Posts: 79 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2006 Posts: 79 | The TH350 or TH400 is a popular choice if you want to go auto. There are a lot of folks supplying motor mounts for this swap. Some are putting in a tubular crossmember for the engine mounts. Bluedawg
Bluedawg
God fearing, Gun toting, Constitution loving extremist.
| | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | Check the archives. You'll find a ton of information on this subject. I would suggest if you plan on running an auto tranny you get one with an overdrive; mine is a 700R4 beefed up for 330 horse.
~Jim
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | 53flatbed: I'm not sure what the difference is in the half ton vs the 3/4 ton but you may want to take a look at my photobucket link below. I have a few pics in there showing the mounts I used and which I like since there is no cross memeber. Take a peek and see if it will help on your 3/4 ton. | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | putting a 400 in my truck, automatic tranny, would late model shifter or what would be good to install | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | 53, I use a Lokar auto shifter with the "Nostaglia bend" Works great. Tim | | | | | Joined: Jan 2002 Posts: 866 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 866 | Same here Tim, I like the looks of the Lokar, definitely works great! | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | Well we installed a chevy 400 in my 3/4 ton and left the striaght axle. ad to install hugger headers and move the steering box 2" to the left. we used the rear motor support from the 235 and modifed it and used it for the front motor supports. i used a 74 nova rear transmission support for the rear and bolted it into place, had to cut about 1" off on each side. used a lokar shifter and works great, got to deal with the low gear rear end so i can go 60 with low rpm's | | | | | Joined: Feb 2009 Posts: 14 New Guy | | New Guy Joined: Feb 2009 Posts: 14 | How did you move the steering box to the left 2 inches. I am placing a 350 sbc in my 1951 chevy 1.2 ton and I am having the same problem with the steering box being withing 1/4 inch the engine plugs.
james | | | | | Joined: Jul 2008 Posts: 149 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2008 Posts: 149 | We used the existing steering box and he welded a bracket to the side of the frame to mount the box too. we cut a small slot to the left of the steering column to alingn the column straight. gona change column sometime. had pleny of room. had to heat up and bend the control arm so it would move correctly. drives and handles great. i put a steering wheel from a 74 nova and it looks better and does not change the effort it takes to turn the steering wheel. send email and i will send some pictures if you would like | | |
