3 members (Hanks custodian, Rich'sToys, Hotrod Lincoln), 136 guests, and 3 robots.
Topics128,149
Posts1,056,816
Members48,454
#543004 06/02/2009 9:24 PM
Can anyone tell me the differences between a 1/2 ton and a 1 1/2 ton 1950's era chevy trucks? I want to start a project truck and found a good 1 1/2 ton truck with a good body. The front clip and cab look the same between a 1/2 ton and the 1 1/2 ton I found.
Cab is the same everything forward is bigger to clear the larger wheels. Everything, fenders, inners, hood, latch panels, gravels shield, grills etc.
Cab's interchange, fenders do not, and I dont think grills do either, but dont quote me on that. Hoods dont. Everything was, of course, bigger on the big bolts. Wheels, tires, some sheet metal all do not match anywhere close to that of a 1/2 ton.
No 'bolt yet, but if you'd like to help me out with that, send me a message! Or check out my wanted add in the swap meet.
The grilles do not match, I tried to put a big bolt grille in a 1/2 ton and it wasn't even close. They look the same but are not.
R Online: Content
Just fix up the 1 1/2 ton. Big Bolts are more fun anyway!! dance grin
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
Parts are harder to come by on the larger trucks.
~Jim
Really? Since when? My CarQuest and Napa have parts on the shelf for mine. Some of the drivetrain parts are the same for over 40 years. I, of course, also recommend going with the big truck,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
