7 members (JW51, TUTS 59, 3800GUY, Otto Skorzeny, cmayna, 52GMC35424JD, 1 invisible),
105
Mod | | | Forums66 Topics128,065 Posts1,055,863 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | | Ixnay Unregistered | | Ixnay Unregistered | I am looking at 1968-72 C20s. All I see listed are AT, no 4 speeds unless the rig is also 4WD. I would prefer a manual tranny. What say you, oh wise sages? Should I hold out for a manual or buy the 350 auto?
Follow up to that query: is the THM 350 preferred to the Muncie 4 speed? What are the concerns/pitfalls with either type?
My requirements: hauling yard supplies, occasional hunting. No camper, no boat, no stumps to pull.
Related query: Should I go with the C10?
Thx
Ixnay
| | | | | Joined: Nov 2006 Posts: 247 'Bolter | | 'Bolter Joined: Nov 2006 Posts: 247 | First of all welcome to the Bolt. I have always been an auto fan. The THM350 is hard to beat, except for no overdrive. The next guy will tell you to go for the 4 speed. We all have our preferences and there is no right answer, it is what works best for you. Good luck Jim | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I would go for an automatic myself. I like 4 speeds too, but it can be a hassle when in traffic. You get used to it like anything else though. Autos are easier on hips and knees. | | | | | Joined: Feb 2009 Posts: 66 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2009 Posts: 66 | My 70 GMC C-10 has a 350 and a THM-350. I wanted to get a manual myself, but the truck came with an auto. I know guys who only drive autos and will tell you to get an auto, I also know the guys that drive manuals in everything, and they will tell you to get a manual. It all depends on you. I like the manual, I would like to get one eventually. I'd say that with the applications specified, you could get away with the C-10 for sure. I don't know what things are like in your area, but 1/2 tons are most prevalent. If you can't find a 3/4 ton with a manual tranny, you won't find a 1/2 ton with one. The THM-350 is arguably the best auto tranny ever made.
"So this year, I am upgraging my policy of zero tolerance to one of SUB-zero tolerance, which is MORE than zero." -Principal Jindraike
| | | | | | Ixnay Unregistered | | Ixnay Unregistered | I've found a C10 w/ a manual and a 4WD, and I'm looking hard at it. The engine needs some work (no big surprise there) and she's not show-room ready, but that ain't what I want. So we're off to the races if she checks out.
Ix | | | | | | Ixnay Unregistered | | Ixnay Unregistered | Went for the 3 speed on a 68 C10. Not a bad project car. All the parts are there, just not on the rig. Previous restorer died suddenly of cancer and this rig sat in the garage for 3 years. Tonight it became my headache. | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | all I can say is.............if an't got 3 pedals, it an't no hot rod..........
now for your truck,,. just depends if you like shifting gears, that's about it.. Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
