4 members (Hotrod Lincoln, Otto Skorzeny, Gdads51, 1 invisible), 93 guests, and 2 robots.
Topics128,131
Posts1,056,369
Members48,441
#537834 05/15/2009 1:06 AM
FINALLY after months and months of the front of my truck sitting on blocks, its back to keeping itself up. Just got my new wheels and tires mounted and installed. This after swapping out the 3/4 ton axle for a 1/2 ton, installing a power steering kit and a 5 lug disc brake kit. Then I decided to work on swapping from a 4bbl carb to a Throttle body injection system for the 235. What should have only took me a few weeks came out to a few months because of work (fulltime 40 hrs a week) and evening college classes. Summer break is here so I have 3 months to get further along, and hopefully get just that much closer to getting my truck on the road.
Some pictures!
http://i175.photobucket.com/albums/w124/rockfan1815/wheels/100_0959.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/wheels/100_0957.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/wheels/100_0956.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/wheels/100_0955.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0911.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0962.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0960.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0961.jpg
Wheels are American Racing AR-23 aluminum 15" 5 spoke, fronts are 15x7 with Mastercraft Avenger GT 235/60R15 tires, rears are 15X8 with Mastercracft Avenger GT 245/60R15 tires. So far Im liking the stance/ride height. I have one item that I will need to change and that is the CPP steering arm on the front axle, I need to flip it upside down so that the ball joint is toward the ground.
Next step is to run all the brake lines from the master cylinder to the front calipers and rear drums. I wanted to wait until the truck was off of the blocks before I crawled underneath it.
Chris, your doing a good job. And with the schedule you have had I think your doing one heck of a job!
I also really appreciate the pictures. I have bought up the gearbox and kit and have the 68 steering column almost back together. Your pictures are worth a thousand words and I like them better than the ones in my kit to install the gearbox...and showing just where the shock bracket ended up. Its just nice to see one in progress are already completed. I plan to do mine as soon as school is out....in 14 days!!!!
Keep up the good work and the pictures. Thanks for sharing.
EDIT: and the wheels look mighty good on there too!
Nice Project ...an them WHEELS sure are PURDY!
1952 Chevy Shortbed
Photos in Photobucket
1 Offline
Looks great ! Your doing a awesome job
Some people are like Slinkies, Their not really good for nothing... But they still bring a smile to your face when you push them down the stairs.
1951 3100 350 TBI Gallery Toddzilla... "$old"
nice work, really like the engine..
must be my eyes but the steering wheel looks like it is almost in the center of the cab... or at least farther to the right then normal..??
Redryder pix
My Hotrod
Lookin' good Chris.
I like the 'Noo Shoes'!
Keep up the good work.You're getting there.
Jock thumbs_up
More pix on Flickr.
looks real good.................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
thanks for the compliments guys!!!
Joker it might be your eyes or at least I mounted it in the same place as the stock column. Its a telescoping tilt so it sticks out a bit further.
Thanks Again!!!
Some new pictures. I flipped the steering arm on the axle so the ball joint is facing toward the ground. The steering link was binding a little bit just sitting still. A good compress of the suspension and there would have been some real bad problems.
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0966.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0967.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0968.jpg
http://i175.photobucket.com/albums/w124/rockfan1815/new%20pictures/100_0970.jpg
