| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2008 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: May 2008 Posts: 142 | I have boxes and boxes of used hardware. Large and small. Screws, bolts washers etc. I do not want to throw them out, rather, I wish to clean, sort and restore them as new. What tool/method is best for hardware restoration? I know the wire wheel is good, but it removes the protective coating and accelerates the rusting of the just cleaned item. Not only that but it takes a lot of time to do each one. I have even tied wire to a group of them, and bead-blasted them, again time consuming.
Has anyone attempted to use a jewelry tumbler? If so, what medium would be best suited? Or what is the best way to protect them after cleaning them to bare metal?
Any ideas out there?
Thanks | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | A tumbler will do a NICE job. My friend uses one to polish a lot of small stuff. I do not know what media to use. My grandson has a "rock tumbler" that I have considered trying to use but its a little late for me  Eastwood offers these tumblers and I would think they have recomendations in their catalog/web site to guide you. Let us know. I'm interested and curious but spending my time on other things right now. I wish I had bought one in the beginning. I could have saved many $$ that I spent at Ace Hardware! | | | | | Joined: Aug 2005 Posts: 424 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 424 | I like to throw the hardware in a little phosphoric acid solution overnight. The next day everything is clean and rust free. It even leaves a protective coating. Also, you can hit them with the wire wheel and they polish right up. | | | | | Joined: Feb 2009 Posts: 37 'Bolter | | 'Bolter Joined: Feb 2009 Posts: 37 | what concentration of phosphoric acid do you use? Whst protective measures are needed. What kind of container do you use - glass? | | | | | Joined: Jun 2006 Posts: 687 Shop Shark | | Shop Shark Joined: Jun 2006 Posts: 687 | I read a post in a porsch website (pelican parts) that the guy used electralosis to remove rust from brake calipers. He said it caused no harm to the part and he didnt use any abrasives. Only the rust was removed. Best of all no time was consumed. Well the parts did sit in the home made vat for a day or two. I found it ( http://forums.pelicanparts.com/showthread.php?t=452132&highlight=electrolysis)
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | If you have a large quantity, how about a cement mixer and sand blast media of just about any type. I seen a cloth dryer drum in a automotive electrical rebuild shop set at a little angle, with media and several pieces of alternator's tumbling away. Seemed to do a decent job.
You Learn more Listening than Talking
I didn't do it, no one saw me do it, you can't prove anything! "Bart Simpson" | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | I read where someone took small items and placed in a clean paint can with some media and threw it in a paint shaker. Another option that may work. I haven't tried but thought it was a great idea. Have fun and good luck Dan
| | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Try This Bit of overkill for nuts & bolts but if you could find a local garage with something similar they may do them for you. We have one at the shop I work at for hubs and other odds and ends, but it hasn't worked for 5, 10, maybe 15 years  | | | | | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | I have in the past used a brass polisher with walnut media from the local gunshop. Does a good job just dont overload it. havent seen 1 in a while unless I go to a gun show. plug it in check in morning still dirty, check after work... most of what I have done was ready in 4-5 hours Brad | | | | | Joined: Oct 2007 Posts: 725 Shop Shark | | Shop Shark Joined: Oct 2007 Posts: 725 | I have found that a vibratory tumbler loaded with bolts or whatever and sand works very well. After a couple of days, parts will be bare metal and the sand will be fine dust. I've used this process for over 20 years with the same tumbler.
best wishes,
Les | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I wonder what its like to live somewhere that the bolts come off in one piece?  | | |
