0 members (),
171
Mod | | | Forums66 Topics128,143 Posts1,056,494 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Same issue as in the fall -- Everything started when the fuel pump died. After cleaning the carburetor and replacing the fuel filter, points, coil, plugs, plug wires, adjusting the points and the timing, the engine is still running a little rough at idle and will cough, stumble and backfire through the carb at high revs or under a load.
I can not guarantee we have the timing or points perfect. And we may not have gotten all the pieces of the fuel pump diaphram out of the carburetor.
Any suggestions or ideas?
Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy John Milliman, it sounds to me like you have a sticking, burned, or too tightly adjusted intake valve. It may also be a broken valve spring on an intake valve, also extremely worn valve guides can cause this, or it could be as simple as a chunk of carbon holding a valve slightly off its seat, hope that helps. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | check the lead to the condenser as it is also psooible to pull apart when the vacuum advance works causeing misfire and it settles back in place. not saying that this is it but have seen it before | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | John, Run a compression test. The only way to get compression back through the carb is through the valves. Either one is burnt, not seating some how or the timing is way off (like 3B says), Scott | | | | | Joined: Sep 2007 Posts: 59 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 59 | Check your valves. I had something similiar happenin and two off my push rods had jumped off the rocker arm. Hope this helps | | | | | Joined: Apr 2000 Posts: 179 Shop Shark | | Shop Shark Joined: Apr 2000 Posts: 179 | I had a distributor / oil pump gear on a 305 get loose on the shaft and give me similar symptoms untill it finally got cock-eyed against the cam and jammed and died for good. At the time I was thinking I needed to rebuild the mech. advance in the distributor because I couldnn't get consistent timing. Before I dug into it the gear failed and revealed the problem.
Joe McNeel
http://mcneelnet.com/~jmcneel/59.html
| | | | | Joined: Feb 2004 Posts: 29,821 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,821 | Put a vacuum gauge on it, and check for any fluctuation at idle, and as you accelerate. If the vacuum has a rapid fluctuation at idle, you've got an intake valve adjusted too tight, or sticking, or- - -worst case- - -burned.
Do compression test, "dry" first, then with about a tablespoon of oil in the cylinder. Last thing to do is a cylinder leakdown test, where copnpressed air is introduced into the cylinder through the spark plug hole and you listen for leakage at the oil filler, the carb, and the tailpipe. Bubbles in the radiator icdicate a leaky or blown head gasket, or cracks into the water jacket. You really don't want to go there!
The vacuum gauge is also useful for timing and carb adjustment. Lean out the mixture screw(s) until vacuum drops, then back them out for the best vacuum reading. Timing is the same basic maneuver- - -retard the timing to get a drop, then advance for the best vacuum number. Good luck!
Backfiring that's not caused by mechanical problems is either lean mixture, or late timing, or both. Jerry
| | | | | Joined: Dec 2007 Posts: 166 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 166 | This is probably a stupid comment but Wynns has a product to run through your engine that frees sticky valves. Ok now I,m demoted back to sweeping the shop floor.  | | | | | Joined: Oct 2004 Posts: 128 Shop Shark | | Shop Shark Joined: Oct 2004 Posts: 128 | If it is a constant sharp barking noise through the carb under load I would suspect a flat cam. Pull the valve covers, start it up and let it idle and watch the rocker arms. If one or more move less than the others you've got a flat cam. I've replaced several of them and the symptom is always the same.
John | | | | | Joined: Mar 2005 Posts: 92 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2005 Posts: 92 | john1, He's working on a V-6 305 not a V-8, LOL, Scott | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Scott,
What's the difference? Why wouldn't John1's diagnosis apply to a V-6 as well as a V-8. I must be missing something here.
Stuart | | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | 305 V-8's are notorious for flat cams, poor hardening process. It's not out of the question on the V-6 but since it's a firetruck, I assume it's a low mileage engine. Until John diagnoses it, all bets are off, Scott | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Great ideas -- Thanks! Actually, the only ones I like are the ones regarding the timing. The other ones are scaring me  I'll let you know! Thanks, John
~ John A kid raised on Hotwheels, Matchbox and Tonka cannot be reasonably expected to own only one vehicle as an adult. 1949 Chevrolet 3804In the Legacy Gallery | In the Gallery Forum1973 IH 1310 Dump1963 Kaiser M38A12001 International/AmTran RE3000 "Skoolie"2014 Ford E-350 4x4 (Quigley) | | | | | Joined: Feb 2000 Posts: 5,223 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,223 | Did it run OK before the fuel pump died?
Can you choke it and get any different response from it?
Did you change anything other then the carb clean out and fuel pump rebuild?
A few things to check,
first, pull the fuel line at the carb, and put a hose on it down to a bucket. Crank it over and see how much fuel its pumping.
If its just a bit, your pump is bad or rebuilt wrong, if its a lot, go back into the carb and check for trash in the jet or a passage ways.
Set the dwell and timing, by ear, by light, or by vacuum. Get it close, where it sounds the best.
Check for fouled out spark plugs or crossed plug wires. Even if a plug wire is on the right plug, it can still cross fire if the wire is questionable.
Check for vacuum leaks at the carb base since you had it off, and check all the lines going or coming from it.
Its unlikely anything major has gone wrong, cam wear will creep up on you and bent or bad push rods make noisy.
Joe | | | | | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | Don't forget to check the fuel outlet on the tank. Had that similar problem once. It was plugged with rust. | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | It's a funny little engine. Did you get the firing order and distributor rotation correct. 165432-clockwise.
Stuart | | | | | Joined: Oct 2007 Posts: 39 Apprentice | | Apprentice Joined: Oct 2007 Posts: 39 | A flat cam that will not let the exhast valve open will cause it to back fire when the intake opens because it doesnt clear out the exhast pressure also a burnt intake valve will back fire through the carb because it doesnt seal,but I would check compression ,recheck your condensor and points real close, mabey try a new set if the compression is good ,I have gotten bad parts new before , also put a vacum guage on it if a valve is not sealing it will jump up and down rapidly .also a spark will miss fire when its under a load Good luck
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | and last but not least..........the good ole cam ....might have a worn lobe.........
but this deal gives me a concern.. your quote " And we may not have gotten all the pieces of the fuel pump diaphram out of the carburetor."
and if not..........wonder where they might go..
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | and on the other hand it may just be old varnished up gas as it does look like it does'nt get driven much.'basically if it gets proper gas and electicity it should run. a compreeion test should tell you pretty much about the rest. going to be interesting to see what the answer is. there should be a pool on who has the correect theory ron | | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Try pulling off the distributor cap and with the ignition on, open and close the points making a spark. If the spark is a crisp "snap" and white/silvery in color it's probably OK. If the spark is blue and flashy the condensor may be defective.
To me it sounds more like timing or a valve sticking or not seating properly. | | | | | Joined: Nov 1995 Posts: 5,723 24601 | | 24601 Joined: Nov 1995 Posts: 5,723 | Ran the truck yesterday -- it appears the issue is fixed. Compression, timing and gap all checked out right in spec. Jimmy rebuilt the carburetor and, in the process, removed a goodly amount of mechanical pump diaphram bits out of the high speed jet -- amazing that enough pieces made it through the stone filter to be a problem like that. Freshly rebuilt carb, new mechanical pump (keeping the new electrical one in line as a standby) and she seems as right as rain. Winchester Fire Parade, here we come!  John Thanks for all the advice and guidance!
