| | | Forums66 Topics128,065 Posts1,055,868 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 26 New Guy | | New Guy Joined: Sep 2007 Posts: 26 | Have heard about testing/turning speedo with a drill. Anyone done that? Use the cable or what? Am thinking about refacing both speedo and gauge cluster, plus a new needle. Any thoughts/ideas/experiences? Thanks, this forum is the best. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | If you got a nice drill you can hook the cable to it and see if it will work. | | | | | Joined: Feb 2009 Posts: 4 Apprentice | | Apprentice Joined: Feb 2009 Posts: 4 | Actually you can spin it with your hand to see if the needle moves. Hook a drill to the cable and spin it slowly to see if the odometer works. I've done it recently. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | I whittled down one of those short pencils on the end to fit the back of the speedometer. Then I chucked the other end in my drill. I thought if something went wrong the pencil would strip out before I did to much damage. | | | | | Joined: Apr 2000 Posts: 199 'Bolter | | 'Bolter Joined: Apr 2000 Posts: 199 | Can be done, make sure it is a variable speed drill! If you just want to see if it works, spin it by hand. | | |
